No sound in frt speakers
    Well i finaly installed a cd player but i still have no sound out the front speakers just the rear, was the same way before i put the cd player in, i thought it just might be the old sterieo,, anyway would that be my factory amplifyer that could be causing this problem??
    Do you have a known good speaker you can wire in at the front temporarily to see if the signal is getting up there?
      well all my frt speakers worked when i first had the car, ill hook up a nother speaker tomorow to see
        Yeah, if the speaker you hook up works, then you need new speakers; if not, you may have a wiring problem and should troubleshoot it accordingly. Try to hook up the speaker directly at the head unit (or at the external amp if you're using one) and see if the speaker works there. If not, then I'd say you've got a head unit/amp problem.
          yea it's wired into my factory amp
            when i wired my old mans radio in rhe 85 colony park, had the same prob, and my first attempt to wire a radio in my 81 i had only one side working, so i came to realize that rewire aint that hard and the sound is great too!
              Doors or dash? My door speakers didn't work at first cause of corrosion. Once clean they worked fine as 24yo speakers can.
                You gotta bypass the factory amp dude, Premium sound sucks that way. I like my premium sound tho.
                '95 Ford Bronco XL -
                sigpic :rebel:
                  is there a way to bypass the amp without having to run new wire's?
                    Crutchfield sells a plug for it yea.
                    sigpic :rebel:
                      sweet, ill have to get one,, thanks mang
