View Full Version : Hissing under the dash
85MercPark
02-01-2007, 11:29 AM
I seem to be hearing a hiss coming from under my dash, under the drivers side. Anyone else had this? I can't locate it because it only makes noise when driving and sticking my head down there at 35 doesn't seem like a great idea. :)
Thinking maybe the E Brake release because it seems slow to release when it's cold. Anyone replace one of them?
mrltd
02-01-2007, 12:01 PM
There are Snakes in motherfuckin wagon!!!!
LOL, it's the parking brake release switch more than likely. It's a white plastic crescent shape on the steering column down by the firewall. Pull the hose that comes from the firewall and plug it. it should go away.
85MercPark
02-01-2007, 12:03 PM
How do you release the parking brake then?
mrltd
02-01-2007, 12:34 PM
with the hand release... or you replace the switch! Or just bypass the switch and put vacuum on the vacuum motor, but the brake will release as soon as the motor is started.
85MercPark
02-01-2007, 01:56 PM
There is no release handle. Guess I will unplug it to test and then replace it if it's bad.
Thanks
boXman
02-01-2007, 02:17 PM
Theres a small lever under the dash, doesnt say what it is. That's your release. I remember that from my '84 GMQ.
85MercPark
02-01-2007, 02:19 PM
Yea I remember now, not real convient location.
I'll just replace it. Can't be too tough.
Easier than that darn thermostat on my Honda.
85crownHPP
02-01-2007, 09:33 PM
the 91 is a push-on push-off E-brake. and it has the auto release... it scared me 1st time it did its thing.
gadget73
02-01-2007, 10:36 PM
I wonder if a later model brake release handle could be installed on the older cars that don't have that thing....
FatNasty
02-01-2007, 11:17 PM
Not possible with anything that just bolts on, its a way different looking setup. I'm sure its possible with a little weld or home made bracket. I have had a handle sitting around for a while waiting for me to find time to install it somehow.
