window
    window
    Hey what's up everybody! Well I tell you what's not up, my rear passenger window. I need help removing the door panel. I only saw one screw at the bottom, unscrewed that and now what do I do? Do I just pull the door panel? Please let me know.
    Another question: do I need to buy another motor or can I get it repaired. It sounds like the motor is running, but the window won't go up.
    Info: 1993 Mercury Grand Marquis GS
    There are two other screws for your pull strap. You have to pop the covers off. Then You will lift your door panel up and out. The window regulator sounds like the problem. You can change it yourself if you have the balls to drill the rivets out of the glass. Personally I just have the dealership do it.
      thanks! will do.
