Howling sound at 55 Mph
    Okay so back right before my rear end went out.. It would hum loudly around 55 MPH, I recently got the rear end switched to 3.73 Posi.. And it still whines... at around 55 MPH The guy who put it in said he would check it out, and see if he could ajust the gears around a little bit to see if thats the problem... What im worried about.. "Could that be the transmission?"
    doubt it, Im gonna try to find a really nice shop to set up my rear end. I don't want to plunk down all this money to go down the shitter.
      it could be, but lets hope it isn't
      2000 MGM LS
        If the bearings in the rear are bad, that could be part of the noise, but I'll bet the gears aren't quite right. Did you go with Ford gears or aftermarkets? Some aftermarket are hard/impossible to get perfect and just make noise. Its also possible you got a bad gear set, it happens.
          The backlash and pinion depth probably are not adjusted correctly.
          -My Homepage, Panther info & FAQs-
          My Mint 96' Mercury Grand Marquis LSE -
          Modifications
          Click My Merc for more Pics!
            I would have to agree with you pinion and backlash.....I have had jasper rears that come in not set right...
            President He Man Woman Haters Club
            Life should not be a journey to the grave with the intention of arriving safely in a pretty & well preserved body,But rather skid in broadside,Thourghly used up totaly worn out & loudly proclaiming...WOW WHAT A RIDE!!!
            http://www.myspace.com/dabearsplace
              Ok so, what do I do to fix it? Ask the guy that put it in.
              It's an Eden Posi.
                It's an Eden Posi.
                I would....you should have some warranty
                  2 Year Warranty
                    2 Year Warranty
                    Take it back tell him what you hear....You are the customer...
                      Just a slight possibility.....tranny tail cone bushing? any drips back there? More than likely gears or bearings?
