View Full Version : recommended trans cooler?
monterey1962
02-26-2007, 08:23 PM
Was browsing and noticed that most seem to go after B&M coolers. Anyone recommend anything specific? Anyone have a part number? Looking to add one in the near future.
mrltd
02-26-2007, 08:53 PM
I am running a hayden from advance. As long as it's a big stacked plate, you are good.
gadget73
02-27-2007, 02:37 AM
Stack plates are more efficient than whatever the other type are called size for size. The other type are usually a bit cheaper though. If you're going to install one, might as well get a quality unit and be done with it.
monterey1962
03-03-2007, 07:28 PM
Which one would be good to roll with ....
ONE (http://store.summitracing.com/partdetail.asp?autofilter=1&part=BMM%2D70255&N=700+400004+115&autoview=sku)
TWO (http://store.summitracing.com/partdetail.asp?autofilter=1&part=BMM%2D70268&N=700+400004+115&autoview=sku)
THREE (http://store.summitracing.com/partdetail.asp?autofilter=1&part=BMM%2D70265&N=700+400004+115&autoview=sku)
gabegt90
03-03-2007, 07:52 PM
the first two should be good justin the last one's a little to small for my taste of course you have to make brackets for it though
DuceAnAHalf
03-03-2007, 07:56 PM
#2, #3 maybe thicker but it does not have as much area as two, the thickness really does not help since that extra 1/2" is being cooled by the air thats already been heated up by the front .75"
Better yet, buy two of #2 and run them both
http://www.tciauto.com/Products/TechInfo/trans_life_expectancy.jpg
as long as i dont hold it against the converter for extended periods of time, my tranny almost never sees 200degrees anymore.
mrltd
03-03-2007, 08:36 PM
I basically have #2, which is installed post stock internal to rad cooler
drock96marquis
03-11-2007, 01:35 AM
I am running B&M's 70264 model cooler
http://store.summitracing.com/partdetail.asp?autofilter=1&part=BMM%2D70264&N=700+0&autoview=sku
It is a good piece, and a nice size both from a cooling stand point, and installation.
I would not advise running multiple coolers in series, this will reduce ATF flow rate which is also bad for your tranny. Running a cooler inline with a factory in-radiator ATF heat echanger is fine, though.
DuceAnAHalf
03-11-2007, 05:34 PM
Drove mine yesterday, tranny fluid never got above 150degrees.
