What is this senser?
    what is this senser for? is it automatic cliemet control or somthing?
    yup - thats the culprit for a lot of peoples lack of heat issue
      yeah pain in the ass to change if you don't have the right tools
        Interior Temperature Sensor. Not sure how it comes out on a Grand Marq, but on a Townie, remove the dash top, and its held in with 2 screws. Very simple to change.
          Quick question - does the box interior air temperature sensor also use a small hose which forces air from the evaporator housing through the sensor?
          The 95+ sensors do, as to creat a venturi effect to suck in the cabin air to prevent stagnant/inaccurate temp readings. Just curious if previous panther applications did as well.
          -My Homepage, Panther info & FAQs-
          My Mint 96' Mercury Grand Marquis LSE -
          Modifications
          Click My Merc for more Pics!
            Yes, usually a white or black plastic hose, looks something like split loom tube.
              Thanks!
              Sounds just like the 95+, almost like a white vacuum cleaner hose
              Modifications
