PDA
View Full Version : 2G Alternator Connects to Oil Sender?
91gmblack
03-06-2007, 09:55 AM
Hi all,
Well, I'm getting ready to do the 3G swap, along with new battery cables and starter cables in my 1991 5.0 GM.
But, looking at the 2 plugs that connect to my present 2G alternator, I notice that out of one plug's loom, is a wire that goes directly to the oil sending unit, down by the oil filter.
I already purchased a new 3G regulator plug and a #4 alternator charge cable w/200 Amp fuse.
Nothing mentions a connection to the oil sender.
Can someone please explain this to me and how I should handle it in my 3G conversion?
Thanks,
91gmblack
85crownHPP
03-06-2007, 02:21 PM
dont get confused - that wire is only in the same wire harness as the ones for your alternator. I promise it doesnt hook into the oil sender :D strip back the loom bewteen the 2 points and you will see.
Lincolnmania
03-06-2007, 03:24 PM
that wire just connects to the low oil level indicatior in the oil pan......it's in the same harness, just isolate the wire and splice it back together
86VickyLX
03-07-2007, 05:32 PM
The Low Oil Indicator is located on the driver's side, near the back of the oil pan.
86VickyLX
04-12-2007, 02:39 PM
Hey today I found out I fried my alternator. And I am thinking of doing a 3G conversion. What does this consist of? What do I have to do? And is there a 1993 Taurus one? And also does it look similar to the other one? As in the original.
