PDA
View Full Version : 1989 LTD Crown Victoria LX 5.0 engine specs.
mfmagicmike
03-16-2007, 04:19 PM
I just bought a (used) 1989 Ford LTD Crown Victoria LX with the 302 CID EFI 5.0 (WINDSOR?) engine and I am desperately looking for these engine specifications : bore and stroke, compression ratio, maximum RPM, maximum torque and horsepower (or kW)?
These informations are pretty easy to find for the previous versions (but which are carburated), and for the later models (but 4.6l engines).
Thanks for Your help!
Tiggie
03-16-2007, 04:27 PM
It's SEFI - Sequential Electronic Fuel Injection. CFI is on the '83-'85 CV's looks similar to a carb at a glance. There is no mistaking SEFI for a carb.
Yes, it is a Windsor engine.
Bore is 4in, Stroke is 3in. Compression is 8.9:1. Max RPM is stock form is probably around 5K. The valves float after that and you don't get too far. Peak power numbers depend on your exhaust:
- Single Exhaust: 150hp @ 3200, 270 lb-ft @ 2000
- Dual Exhaust: 160hp @ 3400, 280lb-ft @ 2200
Hope this helps and welcome to GMN!
Nathan in MI
03-16-2007, 04:29 PM
Hi, Mike. Welcome to GMN! The bore and stroke for the 302 (and yes, it is a Windsor engine) are 4" and 3", respectively. Compression ratio is 8.9:1, horsepower is 150 HP@3200 RPM (160@3400 with dual exhaust), and torque is 270@2000 RPM (280@2200 with dual exhaust). Maximum RPM is going to be in the low 4000 RPM range because of the transmission governor. That seems low, I know, but with the way these engines are cammed, and with the way the exhaust system, intake manifold, and heads/ports are designed, they run out of steam pretty quick if you try to run them much faster than that anyway.
Hope this helps, and once again, welcome to GMN!
Woops--I see Tiggie got to this just a couple minutes before I did.
mfmagicmike
03-16-2007, 04:34 PM
Thanks for the info,
it's a single exhaust, so it should be 150hp@3200rpm.
On the car registration it says 168 kW,(approx 220HP), is that compatible with the 150@3200 or a mistake ?
Regards
mfmagicmike
Nathan in MI
03-16-2007, 04:42 PM
220 HP is more like an HO engine, and your car wouldn't have that. Sounds like a mistake to me.
Tiggie
That has to be a mistake. The DMV isn't known to be the exact resource when it comes to correctness. I usually have to tell them the fees for renewal when I go :).
EDIT: Ooo Nathan got it first this time!
mfmagicmike
03-16-2007, 04:56 PM
I bought this car in Germany in January
Canadian made, California driven, exported to Germany and now it is in Paris, France, with proud 230 000 miles (working fine!).
French officials are very tough on US cars and in order to get a license plate, I have to submit it to numerous inspections, because nothing on/in/under the car meets european security norms (it certainly does, but Ford never imported this car).
Thus I have to make a complete and accurate description (in french of course) of the engine, transmission (with ratios), differential, brakes...
Therefore Your information is very important, so let me thank You again (and for the welcome too.
Nathan in MI
03-16-2007, 05:03 PM
You're welcome, Mike. let us know if we can help you out with any other stats, or any other questions you might have about it.
DuceAnAHalf
03-16-2007, 06:48 PM
any chance of some pictures of your car in front of maybe the Eiffel tower, arc de triumph, or maybe the Louvre?
RugerP97DC
03-16-2007, 07:07 PM
Dat would be da BOMB!!!!
mfmagicmike
03-16-2007, 07:22 PM
Here it is,
Not by the Eiffel tower, only Rhein-side (Freiburg, Germany), but as soon as I get the license plates, I will post pictures from downtown Paris.4807
4808
4809
Blaze86Vic
Sweet! A European Panther!
Welcome to GMN! And again if you need any info just let us know and we'll get back to you asap! As I am sure you are aware it is very rare to see these cars in other continents.
DuceAnAHalf
03-16-2007, 07:28 PM
i would not think the car would be bad to drive in Germany, but how is it to drive in Paris with those narrow streets?
mfmagicmike
03-16-2007, 07:49 PM
Driving in Paris is possible, but You need to look out were You re going. Big boulevards are OK and a car like this one makes everybody stop (out of respect for this american beauty of course). By the way a real eyecatcher.
PS for blaze86vic: must be the only Ford LTD Crown Vic in this condition in France, probably about 10 in France at most
mfmagicmike
03-16-2007, 07:57 PM
Does anyone know 1989 Ford AOD transmission ratios? Here are the ones I have: first gear : 2.40; second gear: 1.47; third gear : 1.00; fourth gear: 0.67; reverse gear unknown.
Thanks for Your advice
Nathan in MI
03-16-2007, 08:05 PM
Those ratios you have for the AOD are correct. I don't know what the reverse ratio is, but someone around here probably does.
Beautiful car, by the way! I love black panthers! :drool:
mfmagicmike
03-16-2007, 08:19 PM
Has anyone experience with hyperlubricants in old 5.0 engines?
packman
03-16-2007, 08:23 PM
Welcome to GMN and might I add, nice CV!!!! I have this movie called Rendevouz; freakin awesome; but I wonder if the streets in Paris are still like that?
mfmagicmike
03-16-2007, 08:35 PM
Hi Packman
I don t know the movie You mentioned, but I guess that streets around here are pretty much like You ve seen
mfmagicmike
Blaze86Vic
03-16-2007, 08:49 PM
Your rear gear (final drive) ratio can be one of two things most likely. Either 2.73 or 3.08. Almost undoubtedly it is an open differential (not posi). The rear is an 8.8" Ford rear with 11" drum brakes. There should be a metal tag located on the differential cover at the rear of the rear axle. This has the code for all the info on what is inside (ie gear, posi)
mfmagicmike
03-16-2007, 09:09 PM
I checked the tag You mentionned but what is written on it doesn t match the 1989 rear wheel drive Ford specifications book. It says V014 D 08 88 9 G24
Off course the differential has an axle ratio of 3.08 (not a traction-lok), code Y.
Do You know were the engine number is located (front of the engine or on the left side)?
thanks
mfmagicmike
OVERKILL
03-16-2007, 09:19 PM
On the HO engines, there was a sticker on the passenger-side valve cover with the number on it. I don't know where it is in the lopo engines, possibly the same spot. I could go check my lopo covers if necessary, as they are in the garage............
mfmagicmike
03-16-2007, 09:32 PM
I have a number on the engine behind the distributor cap and another on the left passenger valve, must be one of these two
mfmagicmike
OVERKILL
03-16-2007, 09:42 PM
The one on the valve cover, is it a sticker of sorts? If so, that's the one.
88Vic
03-17-2007, 12:31 AM
Wouldn't his rear drums only be 10", because I thought only PI models got the 11" rear brakes?
Oh, and welcome to GMN mang, the back vinyl on the black body looks awesome.
Tiggie
03-17-2007, 12:43 AM
Yeah, he'd have 10in drums. Unless he has a Class III towing package, but then he would have had dual exhaust.
Blaze86Vic
03-17-2007, 01:02 AM
Yeah, you're right, I forgot about the 10" stuff since I've never had it. My bad.
gadget73
03-17-2007, 01:57 AM
Nice car! I see you don't have those amber turn signal lenses on the back. Did you get an exception to that, or have they not been installed yet? Seems like all the US cars I've seen that have been imported to Europe have been retrofitted with the amber turn signal.
mfmagicmike
03-17-2007, 06:58 AM
The red turn signals are tolerated in Germany, but here in France I had to make little changes: the wiring had to be redone in order to separate the brake light from the rear position light (only one cable in the US). To have orange turn signals I disconnected the white reverse lights (one on each side) and put in orange light bulbs. I hope french officials will accept that.
Once I am through with the registration I will put things back as they were (french Police doesn t know anything about these cars).
Mr. Land Yacht
03-19-2007, 01:31 PM
OooooOOOOOooohhh! Black Box Vic! The Big Black Box :D
YOWZA!
That's a beautiful Vic!
I like, I like!
welcome to GMN Monsieur!(sorry if I spelled that wrong)
murphmobile2
03-19-2007, 02:54 PM
Hmmmmm... that's a pretty sweet idea if you ask me, lol.
gabegt90
03-19-2007, 06:41 PM
welcome mang sweet vic I know of one 89 grand marquis it's in Lenggries Germany heres the cardomian link http://www.cardomain.com/ride/408593
its really rare to find a box in Europe one of our members is in Australia he has a lincoln town car
