Its been awhile since I have been on here again. This past weekend I finished installing my Comp Cams Extreme Energy XE268H-14 cams in the marquis. It took quite awhile but I got them degreed within 1/2 of a degree of each other. However, I have noticed some driveability issues since the camswap.
1. It feels as if the Torque converter NEVER disengages while slowing down/stopping. Motor is ALWAYS trying to "over drive" the brake system. Even sitting at a stop light as the car "lopes" at idle it is sometimes inching forward.
2. between approx. 1100 and 1500 rpm with very light foot (trying to maintain a certain speed) the car chugs, or bucks, or whatever you want to call it at this point. If I drop the shifter a gear manually it is perfect again.
My questions:
1. Is this normal for a stage 2 cam grind to act like this in a somewhat modified panther?
2. Can this be rectified with a new tune with the Xcal2? The cam specs specify that I would not need a computer tune but then again I am somewhat modified not stock.
3. Is there not enough stall in the torque converter? I ordered a custom built 10 inch stage 2 converter with 3200 stall. I know this will work better for getting off the line but will it help with the bucking as well?
Here is a sound clip of my car on YouTube. Hope you enjoy.
http://www.youtube.com/watch?v=ocNoUzeEpgE
My questions:
