Single to dual exhaust conversion
    Hi all. I recently bought a very low mileage 2005 Grand Marquis LS and I would like to install factory dual exhaust from the LSE. I checked with the dealership and it looks like all I need is the H-pipe and the muffler-tailpipe for the driver side. The cats and pass muffler-tailpipe appear to be common for both. Is my observation correct? Is this conversion possible? Are there any other engine systems to consider? I have a 72 Continental with duals and nothing beats that sound.
    Thanks in advance.
    yes this is true, but if your going ahead with this such conversion, throw on some magnaflow mufflers or glass packs if you want!
      I agree....make it BETTER than stock!
      1987 LTD CROWN VICTORIA, 5.0 EFI, MAGNAFLOW DUAL EXH, RED LANDAU
      FRESH AOD, 3.27 OPEN DIFF, 57K MILES, B&M SHIFT KIT AND R134A A/C
        Passenger side tailpipe and muffler assembly is the same from single to dual exhaust. You got the right idea, H pipe, muffler, hanger, and right side tail pipe.
          If I were you, i'd get two performance mufflers and get rid of the stock mufflers, since those are the most restricting part of the exhaust. If you want cheap mufflers, Summit Turbos are quiet and only $15.
            Would that be the same one with the 460 BB?
              Yes it is. I'm restoring it here.
              The pass. muffler and pipe are in excellent shape so I'm sticking with them for now. I want to keep this mod as low cost as possible.
              I crawled underneath today and had a look. In the parts manual the muffler and tailpipe are two parts joined somewhere above the axle. However what's there now is one piece. If you wanted to remove the muffler you would have to cut the tailpipe just aft of the muffler itself. I'm thinking that factory is one piece but since it would be next to impossible to install a replacement, it is in two pieces. Or if I had factory installed duals then both muffler/tailpipe assemblies would be one piece. Is my thinking correct?
                if you went to a shop, they could do some welding after they cut the mufflers off, and sell the mufflers to the shop, lol, but i belive if you buy all aftermarket parts, it should bolt up
                  That is awesome. I love those old conti's.I saw one in the junkyard a few weeks ago,beat to hell,and I still wanted to take it home with me,lol.
                    I just did my exhaust, here is what came off:
                    Lowest cost option would be to find a used exhaust off a wrecked dual exhaust car, and install it yourself.
                      JF: tsk tsk for cutting off the flanges. Now you'll never be able to just un-bolt the H pipe to replace it should it need replacing in the future.
                        Besides the hangers, after the cats there ain't a bolt anywhere on it. I'm ok with that, by the time it needs replacing, I should be upgrading to headers and high flow cats.
                        I was a little worried when he just started going at the stock exhaust with a sawzall, but I think it came out ok in the end.
                          Success! The new exhaust practically fell into place. Nice rumble, a bit low in volume, but it's there.
                          The new drivers side was in two pieces but its listed as only one part number which confused the parts department as they had never seen that before. :confused:
                          Took one hour labor at the shop. The tailpipe could only be put in place with the car up high on a lift. I would have done the H-pipe and muffler myself but I couldn't get the Y-pipe out of the muffler.
                          JumboFriendly - What about those resonance weights? (The two short black cylinders) Without them you may get unpleasant vibrations in your exhaust system.
                            So you kept the stock muffler and just got another one for the driver side? That's fine, I mean it's better than stock by a long shot, but even cheap performance mufflers woulda made a world of difference compared to the stock single exhaust. But it's all said and done, and I think you'll be satisfied with what you have.
                              Congrats on getting yours done.
                              About unpleasant vibrations, there haven't been any so far...
