What stall speed is our stock torque converter in our cars??
Torque Converter Question
http://www.tccoa.com/articles/tranny...on/page2.shtml
read up on that. I don't know the exact stall speed. Which cam are you looking at? Sounds like comp 274's or equivalent.
I recently installed comps' XE268H cams and then a 3200RPM 10 inch converter.1997 Grand Marquis w/ 126400
TOO MANY MODS TO LIST WITH ONLY 5 LINES OF SPACE. VISIT MY SUPERMOTORS PAGE FOR MORE DETAILS
http://www.supermotors.net/vehicles/registry/15008
I would imagine much lower...from what I was told/understand, a lot of companies put low stall speeds in so that the cars move easy. there is a way to test it if you have a Tach...
just brake torque, but not enough gas to burnout, just a little...when you feel the car start to push against the brakes, that's your stall speed..mine's around 1000 stall...pushes at 800rpm I think...Last edited by Mr. Land Yacht; 04-20-2007, 05:49 PM.sigpic
After my cam install the stock converter seemed like it would NEVER disengage. Stoplights was either neutral or a stern foot on the brake pedal. Be careful if you go with an aftermarket converter. I'm not too terribly impressed with my 3200RPM 10 inch stage 2 converter that I paid friggin $600 for. I'm hoping the new computer programming will take care of it.1997 Grand Marquis w/ 126400
