View Full Version : H4 conversion,, High beems always on!!
Dave84
04-19-2007, 05:51 PM
I put my H4 conversion headlights in tonight,, but now my high beems are constently on,, so i un pluged the high beems for now,,,, dose anyone know how converting to H4 would have caused this?? my H4 headlights are very bright Btw :D
85crownHPP
04-19-2007, 05:57 PM
did you do any re-wiring??? what happens when you turn on the high beam switch?
saiyaneye
04-19-2007, 09:06 PM
What is the difference between the bulbs, other than brightness? Or is there any?
1987LTDmasta
04-19-2007, 09:12 PM
sounds like bad bulbs or incorrect wiring.
Dave84
when i turn on the high beem switch the it stays the same, no i dident do any rewireing, just pluged in my H4 headlights and put it back together
1987LTDmasta
04-19-2007, 09:18 PM
unplug your H4s, plug the high beams, see if they shut off.
gadget73
04-19-2007, 10:02 PM
Sounds like the high and low wires are crossed. Are all 4 lamps on high, or are just the center lamps on high? High beam should be all 4 lamps on high, low beam should be low beam on the inners only. Also I should mention that using H4 lights without a relay kit is a bad idea, and likely to lead to fried MF switches, light switches, and other wiring problems due to the extra current flow.
zwack88
04-21-2007, 01:00 PM
Mine did this too. I actually dig it, it is like a 4 low conversion, then with the high beams on it was like normal, high beams on and low beams dimmed.
Dave84
04-21-2007, 01:57 PM
ok how would i go about putting in some relays?
FordInPossession
04-21-2007, 03:01 PM
The wiring has to be changed for the H-4 conversion. You'll have to take a wire probe and find out which wire is the ground, low power (only one wire would be power under low beam) and high power, then, looking through the glass in the bulb, figure out which post is for the same things. Your ground is not correct on the low beams, causing all the lights to come on.
