that is why i failed inspection besides the head lights they say my blinkers are to slow 50 times perminute and they want me to have 150 a minute
Blinkers to slow
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Go to the auto parts store and ask for a heavy duty flasher. It'll be taller than the original flasher so you may not be able to use the cover over the fuse panel anymore, but your flashers will be much faster.
I use and electronic flasher, it's a normal size and fits just like a reg thermal one. Someone gave it to me a few years ago when I had my first car. Swapped it in to the Grand Marquis when the other was sold. They work very well and have a nice solid sound to them. No clue on cost but they can't be to much.sigpic
1986 Grand Marquis LS 2 Door
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
Come to think of it, it could also be low on blinker fluid.
replace the flasher
Its probably not low on blinker fluid, just needs the fluid changed. The old blinker fluid sludges up and makes it work slower.86 Lincoln Town Car (Galactica).
or simply the fact that the flasher isnt making enough flashes to make the blinker fluid activate
for some reason i feel like you guys are tryin to pull one over on me "Blinker fluid"?!?!? so any way why u said replace flasher do you mean the fuse cause thats what i was thinking it might besigpic1986 Crown Victoria 302 Cold Air,Mac Shorty headers, Full Dual Exhaust with Super Forty Flows, Wagon Suspension with a Full Sound System Replacement 1/4 time 17.486 @ 77.43mph
Blinker fluid. It helps to reduce the wear and tear on the flash-synchro's that make 'em blink. Synthetic fluid will cost a little more, but it's worth it in the long run. This is the best place I've found to get it from, but they're sold out right now. I need to place an order myself.
:evil:
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
We were just pulling your leg, mang, there's no such thing as blinker fluid. Just replace your flasher and that'll most likely take care of the problem. The flasher is a cylindrically shaped metal can down in the fuse panel. The fuse panel diagram in the owner's manual should show you which one it is. Let us know if you have any trouble IDing it.
Originally posted by 83countrysquire View PostI want a picture where this blinker fuild goes?
Sell your panthers and get a Civic, please.
JFWYNick
88 Colony Park LS
Originally posted by 83countrysquire View Postthat is why i failed inspection besides the head lights they say my blinkers are to slow 50 times perminute and they want me to have 150 a minute
We get 21 bucks to a NYS low emissions inspection if we had to pay a guy to test the rate of the "blinking" we would go out of business.1987 LTD CROWN VICTORIA, 5.0 EFI, MAGNAFLOW DUAL EXH, RED LANDAU
FRESH AOD, 3.27 OPEN DIFF, 57K MILES, B&M SHIFT KIT AND R134A A/C
Originally posted by 83countrysquire View Postfor some reason i feel like you guys are tryin to pull one over on me "Blinker fluid"?!?!? so any way why u said replace flasher do you mean the fuse cause thats what i was thinking it might be
A fuse BREAKS a circuit when it's overloaded thus rendering it inoperable.1987 LTD CROWN VICTORIA, 5.0 EFI, MAGNAFLOW DUAL EXH, RED LANDAU
