Starting Trouble (kinda long but PLEASE read!)
    For refreshers, I drive a 1993 Lincoln Town Car. My problem is that sometimes it does not start, it merely clicks. This is generally a problem when I have driven for maybe ten or fifteen minutes and shut the car off, then try to restart is 5-30 minutes later. I thought it was the battery being run down by the air suspension, because jumping it would always get it to start. So today in a parking lot when I couldn't get it to fire up, I just waited like a lost pup for a jump to come along, and decided I'd try the ignition even though it was just doing the one-click thing. It fired up! Thinking it was the battery or terminals before, I have replaced the battery and terminals. I am wondering if it is a temperature sensor, because I think maybe the car is cooling down and then it will start (and the jumping really had nothing to do with it, the car had just cooled from sitting.) Also, the car has one of those "outside temp" readings on the dash, and even though it's mid 70's outside, the dash says it's -13 degrees farenheight. Please help! I am really broke right now and I need to be able to fix this myself, even though I own zero diagnostic tools. But I could probably replace a sensor. Which one would it be? Maybe my Haynes manual could help me find it. Thanks alot guys!
    Back in the saddle again!
    2004 Crown Victoria Police Interceptor in Unimaginative Bureaucratic Brown
    Bone stock... for now.
    Hi Chuck Norris
    Check out the starter terminals they are known to corrode on a 281 Town Car, barring that I suspect you have a bad spot on the starter commutator.
    Regards
    Dereck
    President and founder of The Turbine Wheel Appreciation Society and Little Debbie Cake Connoissuer
      my truck was doing quite the same thing. It turned out to be the starter cable and the starter. i had replaced the starter, it was still doing it, so when i checked the wiring after that, i found green death in the starter cable.
      as far as anything with that temp sensor, that only pertains to the climate control and user convenience package
      oh, also, i dont know if it has one or not (my docs only go back to 96ish) but see if there's a starter solenoid, that could be causing it also
      GMNRadio DJ, Podcast Co-Host
      95 S10 93 Accord
        Hi Seneeb
        Separate starter solenoid finished when the AODE transmision was fitted mid Feb '92, after that is is part of the starter.
        Regards
        Dereck
          Yeah, Derek, you're right. So if it's the selonoid, it's the whole starter. However, there is still the possibility of it being the "starter relay", which thankfully is a rlatively easy to replace part and shouldn't cost alot. I think I'm gonna try that first (I'd check the connections at the sterter terminals first, but I don't have ramps, and I really don't like working under a car supported by jacks or stands.) If that's not it, I will take it to the shop and let them raise it and check all the connections, and replace whatever is wrong. I have a good, competent mechanic whose prices are fair and he doesn't mark up parts more than about three dollars to cover his gas.
            Hi Chuck Norris
            You havent got a starter relay, the only relay in the starting sytem apart from the solenoid on the starter itself is the interupt relay if you have the factory anti-theft system, if this relay went bad your starter would not even click.
            You should be able to get the starter solenoid separately from a rebuilder but ususa;lly it is not much cheaper than geting a whole re-man unit.
            Regards
            Dereck
              A friend I know had this same problem. Not sure what year town car it was but it would start if it was jumped. It was the starting solenoid on the fender. If there was a contact between those two screws, the car would start right up. It might be the same problem. I don't think this will hurt but try taking a screw driver and make a contact between the two main bolts of the solenoid. If this problem is all the time and this makes it start, then it is the solenoid. It could be signs of a going bad solenoid. A hot spot perhaps.
                Hi 86VickyLX
                Am I talking to myself in this thread? Doesnt anybody actually read these threads?
                In post # 4 I could have sworn I said thatthe separate fender solenoid was deleted in 92, maybe I just drempt it?
                Regards
                Dereck
                  Hi Dereck,
                  I'm Pretty sure they didn't. My Mom's 94 Vic has a solenoid on the passenger's side fender.
                    Hi Dereck,
                    Hi 86 VickyLX
                    Holy fucking shit I am talking to myself and nobody does read the entire thread!!!
                    Chuck Norris has a '93 TOWN CAR, it is as simular to your mom's 94 Crown Victoria as my cock is to a cabbage.
                    Regards
                    Dereck
                      :lol:
                      Actually, I think it's easy for us CV/GM guys to not realize some of the weird differences that are unique to Town Cars. I know I would assume the same thing about the presence of a remote starter solenoid (especially since it's been a slight trouble spot on both of my cars), though apparently I would be wrong. :p
                        That, my friend, was AWESOME!!
                          Hi Dereck,
                          I have read every every word of your posts actually, and I have found them quite delightful, as well as helpful. You seem to be 100% correct in everything you've said too. How do you know so much about American cars living in England? Do they even sell Towncars over there? Or any Panther for that matter? I can't image driving one of these land barges down those curvy city streets I always see in movies that take place in England and France.
                          Regards,
                          Chuck Norris
                            I'm inclined to agree, either the starter is giving up the ghost or the connection or cable is bad. All will cause exactly these symptoms. Bad ground connection to the engine block can also do the same thing.
                              Originally posted by Dereck View Post
                              Hi 86 VickyLX
                              Regards
                              Dereck
                              Maybe, but what does Chuck Norris see? Maybe there is one. I've seen them not only in my mothers Vic. I am aware of the many differences between Towncars and Vics/grandmarqs. And as I said, I was not sure what year my friends town car was. That had one. Whatever.
