So what did you use to pull it out? I don't see any holes drilled in it to put bolts in and pull it out? Did ya use the pops-a-dent?LOL J/k It does look alittle better.
u dont need a dent puller, you can pop the dents back out from inside the trunk! :slug:
No no no. There's more to it than that. You would change the geometry of the rest of the body around that quarter panel fool. You've got creases and bends that will change and you'll be fucked for sure. Pushing it out can be a good idea in some insances.
