Piotr's 359ci Windsor Build
    I'm making a thread to chronicle the build up of my new motor. Right now the block, crank and rods are at the machine shop. Its been bored .040 over, tanked and magged, the crank got turned .010 and the rods are getting shot peened and reconditioned. I'm dropping off the cam bearings, rod bolts, and freeze plugs and stuff today.
    I went to summit yesterday and picked up the engine rebuild kit, cam and lifters, roller rockers, timing chain, and some other goodies. My pistons were out of stock and are coming from georgia. I'm putting the engine together all by myself too.
    Right now heres what its gonna look like
    359ci
    9.5:1 compression
    speed pro hyperucraptic pistons
    comp xe 284 hydraulic cam
    world windsor sr heads, shaved .015
    1.6 stud mount roller rockers
    I still need to find a victor jr or weiand stealth intake. I'm kinda leaning towards the victor right now. I also need to find a junky holley 4150 750 dp carb to rebuild. I'm gonna put it together with a proform main body and billet metering blocks. I need an oil pan and pickup still, and a bunch of other little shit thats gonna nickel and dime me to death.
    I'm painting the block dark blue and should look pretty cool when its done.
    Can't wait, mang!!
      sounds great Pete!
      I thought you were painting it Gunmetal?
        Sounds good, but I think with those heads, a victor intake, and carb, the motor might be a but of a dog down low, but it also depends on what the specs on that cam are and what kinds stall you gonna run
          DURATION
          int 284 dur @.050 240
          exh 290 dur @.050 246
          LIFT
          int .541
          exh .544
          110* lobe separation
          I'm swapping to a 5 speed next, so I'll have a mismatched combo for a little bit, I'm trying to think ahead.
          Colin, I couldnt find a gun metal I liked so I'm going dark ford blue.
            ah ic.
            I like the Gunmetal paint Bobert used to paint his woodtrim...if I can find it in high heat, I'll go with it...
              i have an old holley 4bbl at my parents house.....i think it's a double pumper......no clue where it came from lol
                Piotr is German yes?
                  Polish I believe...help us out here Pete.
                  btw, Pete, go on Corral.net and PM a guy named "mattponch"
                  his actual name is Bill...he lives by me and usually has a lot of engine parts...he might be able to hook you up with a Victor Jr. Intake.
                  or at least search in their classifieds...
                    Minus the heads and cam, that motor is essentially a twin of my own. You're going to like it a lot. No roller conversion planned? Now would be a good time.
                      yes... its Polish
                      Flat tappet works for me, the retrofit kit aint too cheap either.
                      I'm hoping to score a used intake and carb off ebay or classifieds. I gotta be patient tho. Scott, if you got an old double pumper around, I'd be really interested. Let me know what you got mang!
                        can't wait to see how it turns out
                          I have a performer RPM available...i can bring it to sf to save on shipping
                          '80 Town Coupé
                            Air gap or non?
                            -Matt
                              update
                              getting the block and stuff back this week
                              Got most everything now, just need an oil pan, carb and pushrods. I cant wait to start putting this thing together!
