High Idle
    High Idle
    Good day.
    Ever since I cleaned my system with Seafoam, the idle on my '91 GM runs high and doesn't want to kick down. I've adjusted the idle screw many times but it always seems to go back to the high idle in a few days. The gas pedal also sticks when the idle is too low. Any ideas on a quick fix?
    Thanks for the input...
    1991 Grey Grand Marquis LS Sedan
    61,000 Miles
    1998 F150 XLT 4X2 Flareside Fire Engine Red
    52,000 Miles
    http://www.cardomain.com/id/hdlogistics
    first check for vacuum leaks, make sure all the sensors are plugged in
    check the throttle body, it may be carboned up and sticking
      Which way did you put the seafoam in thru the brake booster or pcv valve? Which ever way check there first..
      The Best
        I did the seafoam through the brake booster. Looks like all the vacuum lines are all connected and the throttle body is clean. Could it be a defective sensor?
        61,000 Miles
        52,000 Miles
          Finally found and solved the high idle & gas pedal problem. There was a metal burr on the butterfly valve causing it to stay open. Once I filed the burr away, no more problem. Thanks to seafoam, the car idles and runs very smooth...
          61,000 Miles
          52,000 Miles
