View Full Version : Possible Faulty MLPS in '94 Grand Marquis
Long time reader, first time poster.
I drive a '94 Grand Marquis and lately the tranny will randomly drop out of gear on the highway and feel like neutral. Sometimes it will make a random downshift to 3rd or 2nd when cruising on a flat level road and sometimes it feels like it hangs up in neutral but if you slow down to 30mph it will pick up first and hold it but as soon as i back off the throttle it will drop to neutral and not give me the rest of the gears for a minute. Does this sound like a MLPS issue? When its not acting up it runs like any aero-body mod motor panther should.
Thanks for all your help.
88MercWagon
07-30-2007, 08:49 AM
Have you checked your fluid levels? Low fluid can cause a transmission to do all sorts of weird things.
Also, check your TV cable bushing, located on the throttle body, and make sure it is not disintegrated.
Pirate
07-30-2007, 10:39 AM
Yes, it sounds like a MLPS issue. Run codes, and see if anything comes up.
88grandmarq
07-30-2007, 11:16 AM
Nice try, but late 92 up uses an AODE, meaning the transmission is electronic and does NOT have a TV bushing or cable.
93-95 cars are notorious for the MLPS being faulty. like BSP says, run the trouble codes.
thanks so much for the responses. My fluid level is good and the fluid looks clean as it was changed less than 10000 miles ago.
I have never had the o/d off light flash at me but when i bring it into the tranny shop i'll have them scan it.
Just curious does anyone know how to get a new horn button for the '90-'95 steering wheel the one on the right of mine came off and i think the plastic clip thats supposed to be on it is broken off.
What can i expect to pay for them changing out the MLPS?
88MercWagon
07-31-2007, 03:58 PM
:doh: :blush:
just got it changed an hour ago so far so good. I'll do some highway running to try it out. The chassis and components under the car looked pretty so thats good.
