Alright, I was looking into doing the T5 swap and I came across a Borg Warner Transmission at a great price. it's a GM Tranny but what's the difference? I did a few google searches and couldn't find the info I needed. Is there anyway to make it work?
Borg Warner T5?
I picked one up a few years back, thinking the same thing you are probably thinking.
Unfortunately, it turned out to be more trouble than it was worth. The input shafts are different lengths, and the shifters are in different places. The spline count and the bolt pattern for the bellhousing are almost certainly going to be different as well.
The one that is canted to one side a few degrees, is for a camaro IIRC, but I think that the bellhousing is what makes it that way, but I could be wrong.Owner of the only known 5 speed box wagon with a lift kit.
Axle codes
Open/Lock/Ratio #
G / H / 2.26
B / C / 2.47
8 / M / 2.73
7 / - / 3.07
Y / Z / 3.08
4 / D / 3.42
F / R / 3.45
5 / E / 3.27
6 / W / 3.73
2 / K / 3.55
A / - / 3.63
J / - / 3.85
Borg Warner is the company that manufactured the T-5 for both Ford and Chevyhttp://secondhandracing.com/Home.aspx
what trans does the 94 and up mustang use? can you use a v6 trans? i see alot of 94-99 mustangs, but they are all v6's
Originally posted by lincolnmania View Postwhat trans does the 94 and up mustang use? can you use a v6 trans? i see alot of 94-99 mustangs, but they are all v6's
the T-45 is a T-5 with an integrated mod motor bell housing.
the V-6 T-5s are not the same as the v-8 t-5's. my brother is using a v-6 t5 behind his 302, the input shaft is different legnth and you need a certain bellhousing for it to work properlyhttp://secondhandracing.com/Home.aspx
