Mustang AOD
    Mustang AOD
    What needs to be done to get a Mustang AOD into a '88 Crown vic? There's a cheap one for sale locally Rebuilt with a Shift kit and new 3000 stall converter. Can I just change the tail housing or something?
    Resident diesel addict
    The tail housing is the same. only LINCOLNS have longer tailhousings. You would need to swap the shift linkage. Everything else is the same.
    However, unless you ahve a TON of motor work done, it'll be a bitch to drive and it'll never shift.
      Shift linkage but thats it. Works otherwise, but it will shift late due to the higher speed governor. HO swap, or just switch the governor in the trans and you're good to go. New governor is like 15 bucks or something.
        At light and moderate throttle, the different shift points are NO BIG deal. If the higher shift points make you sad and you loose sleep over it, you don't even have to switch the governor. The piston and spring is all that you need to switch.
          If you wanna have a floor shifter now is the perfect time to install one, if the Mustang linkage is anything like the late-'80s-mid-'90s T-bird you will only need to cut one (for the shifter body) and drill four (for the bolts) holes in the tranny tunnel, flatten the tunnel a bit, and drop the shifter in.
