PDA
View Full Version : Twin turbo 351W box...
torquelover
09-30-2007, 10:18 PM
Anyone seen this yet?
http://www.supermotors.net/getfile/568650/fullsize/tractionltd-018.jpg
:kneel:
Nathan in MI
Details?
torquelover
09-30-2007, 10:20 PM
Dunno the guy. It's from a SM site:
http://www.supermotors.net/vehicles/registry/media/568650
Should get him on GMN if he's not on here already.
Nathan in MI
09-30-2007, 10:28 PM
Man, that's a neat setup. Total sleeper, too!
torquelover
09-30-2007, 10:34 PM
Uh huh. Very inspirational...
interceptor1985
09-30-2007, 10:45 PM
Bow down to the twinn turbo crown Vic god!
FastGallopingPonies
10-01-2007, 06:45 AM
Only in my dreams... so I thought
mrltd
10-01-2007, 08:28 AM
Interesting pipe setup...
Pirate
10-01-2007, 03:07 PM
Is it just me, or does it look incredibly cobbled together in some spots?
mrltd
10-01-2007, 03:17 PM
That inlet setup is kinda goofy. Move the damn battery to the trunk and have inlets on both sides.
1987cp
10-01-2007, 08:11 PM
That thar thang's givin' me ideaers........... :3gears:
nitroracer
10-01-2007, 10:46 PM
So how soon before we have him on here to find out how she runs?
gabegt90
10-02-2007, 12:53 PM
dam that's kick ass we got to get him over here
phayzer5
10-02-2007, 01:10 PM
can anyone id the turbo's? I'm wondering why he hasnt lopped off the choke tower on the carb yet either
DuceAnAHalf
10-02-2007, 01:54 PM
can anyone id the turbo's? I'm wondering why he hasnt lopped off the chock tower on the carb yet either
probably a small T3/T4 like a turbo coupe or small import
mrltd
10-02-2007, 03:45 PM
look like hybrids, definately a t3 center and hot side, and kinda looks like a 50 trim front... Ford wastegate setup...
Dave84
10-02-2007, 05:28 PM
That thing must fly.
P72Ford
10-02-2007, 06:19 PM
I'd definitely agree, not that I want to discredit someones hard work. I have seen much worse fab work, but it does look a little goofy. The carb set up is lame IMO. He should have gone with EFI; the idea of turbos blowing through a carb isn't appealing to me.
Also, aren't those turbos kind of small? I'm not really up on turbos, but they look tiny to me. Obviously they aren't like some of the huge ones I see on cars in MM&FF, and understandably so.
definitely lots of work though, and that I can appreciate. I don't want to bust this guy because he has something truly unique.
DuceAnAHalf
10-02-2007, 06:30 PM
nothing wrong with blowthrough carbs. a guy i know has a 306 with ported edelbrock performer heads, blow through c&s carb, 80mm turbo. runs 9.60s @145 on 17psi, thats on a 8" tire and stock suspension
and when you use twins you can use small turbos. two turbos off of MT turbo coupes are big enough for a mild 351
P72Ford
10-02-2007, 06:43 PM
Thanks for clearing up the turbo issue. I'm sure theres no problems with running a blow through carb (I've seen it more than a few times). However, it just doesn't sit right with me. It wouldn't be something I'd do personally.
interceptor1985
10-02-2007, 09:16 PM
Smaller turbo's are better for lag, The big one's have much longer lag time and can be pretty unpredictable to drive.
gadget73
10-02-2007, 09:54 PM
maybe I'm dumb, but why is there a spark plug in the plumbing on the passenger side? Does that serve some actual function, or is it probably just there plugging a bung ?
and good lord, the smog pump is still there lol
Still, pretty badass
1987cp
10-02-2007, 09:57 PM
You know, I noticed that too and then promptly forgot. I'm pretty sure I've heard something about running a turbo motor a little rich at low RPM and then lighting off the raw fuel in the exhaust to spool up the turbos in a hurry - but never having built a turbo car, I may have it completely sideways and upside down. :p
DuceAnAHalf
10-04-2007, 04:00 PM
the picture caption says that its there filling in the O2 sensor bung.
Pirate
10-04-2007, 04:28 PM
The problem with blow-through carbs and turbos is that the boost-curve and fuel flow curves don't match. You have to make the carb add even more fuel than normal, and most normal carbs, unless suitably modified, won't keep up with a turbo/turbos, and go lean. You have to buy a modified carb, or add an injector to get more fuel in.
Mercracer
10-04-2007, 05:28 PM
It is silly to try and tune a blow through carb in your backyard. There are professionals who can tune a blow through setup making 1000HP or more.
Even if you cobble together a home built turbo system to save money, you should be spending the money on a professional dyno tune or you have more than likely built more of a bargain engine killer than a bargain performance engine combination.
1987LTDmasta
10-05-2007, 08:32 PM
redneck engineering!
Mr. Land Yacht
10-08-2007, 06:48 PM
wow..that is friggin' kool as heck!
