Townie door handles
    Townie door handles
    Are they as easy as the two nuts that you see on the back of the door handle cavity??
    Any cheap source for the door handles?? Im supposed to fix two in this chick's 80's towncar... :heyhey:
    It think there were only 2 bolts on the back side I messed with on it the yard. try the junk yard might be cheap
      they bolt on yes.....cheapest ones i have seen were on egay
        Ohh! Nice. I would say a u-pull-it.
        Or the help rack! GOod luck!
          u-pull-it
          I think that's what he was hoping for...:heyhey:
              naw if i can find a HELP one for cheap Id go for that.
              She will be paying for it, so why make more werk for me
              Im glad they arent riveted in like vic/gmq ones. arent they???
                Once you pull the 2 nuts, it comes off. there is a plastic clip holding the rod on but thats it. Once you get it off, the actual handle is riveted to the back plate, but you don't take it apart or anything. usually the pot metal on the corner of the handle will snap and you can't do anything with it but replace it. Mine was loose and I tightened the rivet back up with a hammer, a drift, and using my bench vise as an anvil but thats rare.
                  the vic ones are riveted?
                    Im unsure, but thats what i want to say
                      Natch, why couldn't they keep the Towncar, closer with the vic and gm?
                        vics and gm's have riveted on door handles.....yes they are inferior
