I have heard that a special tool is needed to push in the calipler pistons when replacing disc brakes. Is this true for both front & rear? Can't I just use a large c-clamp like I've done on all my other disc brake cars? 2000 Grand Marquis w/o antilock
Disc Brake Replacement, need special tool?
the problem is that they use dual piston calipers, so if you use a c-clamp you wont compress both calipers evenly. you would have to use two clamps at the same time. also you want to crack the bleeder before you compress the pistons, otherwise you can damage the ABS pumphttp://secondhandracing.com/Home.aspx
Tools?
Thanks,
Another few questions:
Rear Calipers: I looks like there is more to remove than just the calipers, are the caliplers part of the parking/drum assembly?
It looks like the bolts that hold the front calipers are two in number and are regular hex head, not allen head.
Is this true?
No, the calipers are not part of the parking brake assembly. Those are little drum type shoes inside the rotor, behind the axle flange.
There are just 2 bolts to remove on the rear caliper and it comes off. They should be allen key type I believe. The ones on my car at any rate.86 Lincoln Town Car (Galactica).
Originally posted by zwack88 View PostWhat I always did when I had my 2000 was use the old brake pad and put it on there and use the c clamp and compress them that way. Worked great.
I use that method on every brake job, even on single piston calipers to avoid damaging the piston with too much pressure on one point.1987 LTD CROWN VICTORIA, 5.0 EFI, MAGNAFLOW DUAL EXH, RED LANDAU
FRESH AOD, 3.27 OPEN DIFF, 57K MILES, B&M SHIFT KIT AND R134A A/C
Geez... Thain and Duce, the experts, were sleeping on the job again!!1983 Grand Marquis 2Dr Sedan "Mercules"
Originally posted by Grand_Marquis_GT View PostX3.
Geez... Thain and Duce, the experts, were sleeping on the job again!!86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View PostI thought everyone knew the old pad and C clamp trick. The fun ones are non-floating calipers with opposing dual pistons. Can't use that trick on those.
Geez... Thain and Duce, the experts, were sleeping on the job again!!http://secondhandracing.com/Home.aspx
Originally posted by gadget73 View PostI thought everyone knew the old pad and C clamp trick. The fun ones are non-floating calipers with opposing dual pistons. Can't use that trick on those.1983 Grand Marquis 2Dr Sedan "Mercules"
Last Question, another special tool?
I was at NAPA, the guys there said I might need this $10 tool the you attach to a ratchet with an extention and twist while pushing the piston back into the caliper, otherwise you wil blow out the piston seal first time you use the brakes. The guy said you could NOT use a c-clamp when using this tool that grabs the top of the piston so you can twist it.
Anyone know about this?
Thanks!
you dont need that stupid tool.....i use a big screwdriver to push the piston in while it's still bolted up to the rotor......pull the caliper, replace the pads, go do the other side, put it all together, pump the brakes up and drive it
