dash speaker size?
    dash speaker size?
    Does anybody know what size my 2 front dash speakers are in my 89 GM?
    4'' speakes bolt right in, i put one mounting tab under the dash plate and screw in the other.
      It ain't that easy. Most 4" require a lot of depth, and it ain't available. Find some with the least amount of mounting depth you can. I think it's an inch or so.
      '95 Ford Bronco XL -
      sigpic :rebel:
        speaker size
        Wouldn't a 4.5 or 5 inch speaker bolt right in without any mods?
          i have 4'' rockfords and pioneers and work great!
            My brother put a pair of Mb Quarts in my dash 10+ years ago and they fit fine. Like they said, pay some mind to the depth. One on those general offset ratchet screwdrivers is a really great help when working in this area.
            1986 Grand Marquis LS 2 Door
              4" is all the bigger that hole is, its the depth thats a bigger problem. Shallow speakers work. I'm actually using 3 1/2" Boston Acoustics with adapters made out of a tupperware lid.
                IIRC, there is a bit of room between the dash pad and the metal part. If you want you can probably cut some 1/2" thick rings and mount 5.25" speakers. May have to cut some away from metal part too. But an extra 1/2" of mounting depth can help lots.
