Big problem with my MGM 95' ..
    Hello ... I'm a new here ..
    but I have a BIG problem with my MGM ...
    In the last weeks, the EATC was on/off alone some time ... after .. more frequency..
    last week when I pushed the brakes/hazard/turn signal, the engine shut down some time after ..more frequency...
    and today ... imposible to star it
    I have only power on my headlight and cluster... that' s it ... no radio/heater control/hazard/brake lamps/turn signal and no fire on my coilpack ... with my engine won't start ....
    no fuse was blown ....
    I'm lost .. lol
    Have you checked the underhood fuses and cables going to it?? Also check for corrosion on your starter and battery terminals.
      I found today a problem with my ignition switch box ... and wires run out of this box .... but .. no more
        It's '95, not 95'
          some bodys are ables to find how work the ignition switch on '95 MGM ? and wire color what it's do .. (before the ignision switch .. after it's ok.. but battery to ignition switch ... I don't know what wire do .. I search and search and I don't find anything
          please ...
