View Full Version : Car not starting when I want it to
danbraniff
01-14-2008, 08:03 AM
Hey, My 92 Marq is having troubles starting when i want it to, when I go and turn the key sometimes all I get is a click from the solenoid. However I let it sit for 10 -15 minutes and the it starts back up. It does this often. However when it stops doing it it doesn't do it for like a week and then the problem starts up again.
I already cleaned up all the connections on the solenoid and starter. Is there anything else I can do? Or any thoughts on what it is... I think its the starter personally but would like other opinions.
Rizzo
01-14-2008, 08:21 AM
This sounds EXACTLY like the events leading to my starters DEATH.
Same symptoms. You may want to buy one and keep it in the trunk along with what ever you need to change it...and a crappy blanket.
NO JOKE.
danbraniff
01-14-2008, 08:34 AM
Thanks for the quick reply, yeah I am going to bring it to the shop on wednesday to get the starter replaced, any idea how much this will run me?
85crownHPP
01-14-2008, 09:07 AM
yeah, if its orignal Id go on and change it
Rizzo
01-14-2008, 07:48 PM
If I had a guess...Geez...Less than $100. Maybe $60. BUT there will be a core charge/refund.
Been so long since I did mine ( 4.6 engine ) I just cant remember
danbraniff
01-15-2008, 07:23 AM
Well I had a starter, I had a whole engine and everything, only thing was it was a 92 CV with the AODE tranny, and I just have the AOD.
Rizzo
01-15-2008, 02:56 PM
So youre saying you have a starter and you dont think it will fit ??
Use ANY online parts store and search for the starter you have and then the starter you need...Numbers match ..Youre golden.
gadget73
01-15-2008, 08:52 PM
aod and aode starters are not the same. 2 bolts on AOD cars, 3 on AODE cars. That'll be a mini starter, about 150 bucks I think.
