FNG with a Wagon
    FNG with a Wagon
    Hey guys,
    I've been hanging around CVN since 2003 and I can't believe I never knew about this site. It seems like days go by between new posts in the 5.0/5.8 forums over there. It's great to see how many boxes and overall activity there is on this site. There's even a Wagon forum... awesome!
    So a little about me. I got my first GM back in '02 when I inherited my late Grandpas '89. It was a great car but I couldn't take it with me from Calif to Ga. Bummersville, population: me.
    But the box bug bit me and I had to have another. I found an ad last August for a running/driving '88 GM with 98k for $400. I called right away. It turned out to be a really decent Colony Park (wasn't expecting that!) that has spent it's entire life in South Ga. I got every piece of documentation possible for the car including the original window sticker.
    Once I scrubbed off the old man funk, it was solid but rough at the same time. Totally solid body, literally zero rust anywhere, but needed a bunch of mechanical fixes, and it had several electrical gremlins. I rebuilt all the window motors, replaced the lock actuators, the fuel sending unit, alternator, radiator, water pump, t-stat, injectors, hoses, belts, all tune-up stuff, rewired the tow-package harness, full brake rebuilds front and rear, all 4 shocks, IAC, PCV, P/S hoses and lines, upper and lower intake gaskets, a throttle body rebuild and even head gaskets. I replaced a bunch of auto-climate control related parts and a whole bunch of interior trim stuff. I then painted it black, installed a set of 01 Explorer 16's and lowered the front 3". Total investment including home garage paintjob... $1250.00. I've put on 5k miles (including a 1300 mile trip) without a hiccup so far. How cool is that?
    Anyhow, sorry about the novel, I'm excited to be here. Looking forward to getting to know you all!
    Ted
    '88 Merc Longroof
    Wood stickers rule.
    to GMN!
      how did you lower it 3"??? any alignment or tire clearance issues??
        Sweet wagon! The wagon guys on here are gonna love another member, lol.
        I'd love to see some larger photos of your car too!!
          to GMN mang, nice wagon. Are you using the stock front springs but with a coil removed from each? Looks good.
            Always good to see n00bs with wagons. That sounds like one heck of a score! The sig pic looks good; looking forward to seeing more pics when you get time.
              Hey man ..Good to see you over here as well.
                Welcome! You really accomplished a lot with how (relatively speaking) little money you spent! We need to see more pictures of that car.
                  I sawl your car on cvn really nice colony park. welcome by the way
                      You painted it yourself? Looks pretty good in the pics for a home-spun paint job. Welcome to GMN! You'll find here that the 5.0/5.8 section is the better of the two as far as getting info quickly. However, our 4.6 section isn't shabby either. This is a good place with a pretty nice atmosphere overall. Lets see more posts and more pics!
                      Back in the saddle again!
                      2004 Crown Victoria Police Interceptor in Unimaginative Bureaucratic Brown
                      Bone stock... for now.
                        Nice wagon!
                        North Atlanta? Ever go to the Southern Superheavy Shootout at Atlanta Dragway?
                          Got a few pics up for you guys... hope I did it right!
                          Ted
                          '88 Merc Longroof
                          Wood stickers rule.
                            And a few more...
                            Ted
                            '88 Merc Longroof
                            Wood stickers rule.
                              Basically, I disconnected the front suspension at the upper ball joint, removed the coil spring and trimmed one full round off of it using a cutoff wheel. I reinstalled the springs with a fresh set of shocks and went cruising. It drove just fine immediately after, but I did have to realign the front end and round the fender lip slightly. Fortunately, the fender trim does not curve under the wheel lip on wagons like it does on sedans. I just rolled the fender and the trim stayed original. I'm running 235/65r16 in the front and 255/70r16 in the back. No rubbing at all from the rear.
                              Ted
                              '88 Merc Longroof
                              Wood stickers rule.
