Cold Air Intake
    Cold Air Intake
    hey guys whats i was wondering what CAI should i get for my 89 Vic
    LINK TO INFO
      i have heard that mustang ones fit on cv seeing as they have the same engine
        mustang ones aren't usually bent quite right. the intake on a mustang faces the other way, and the fenders are shorter
          i would look at monterey's link. he has a good write up on how his id done. here are a couple pictures of mine. if you can move your coolant overflow bottle, you can get better airflow to the filter. i left mine and it gets air from the gap between the 2 reservoirs and is wedged into place.
          Addicted to 86-87 Panthers
            ok sweet ill put those tips to use
              Not quite the same engines....
              None are truly cold air intakes, and don't help much for performance. They make more noise though.
                I made my own. I wish I had pics of it I cut a hole right where that flat spot is just in front of the reservoir bottles and ran a long tube from the throttle body to right behind the bumper and then wrapped it in a insulation that you can find at summet or sometimes at the auto parts store. I'd use 4 inch flexible exhaust tubing if you can find any and put a filter on the end....Just be sure your careful about water and puddles and stuff like that.
