p71 trans problems
    p71 trans problems
    ok guys I need your help im working on a 2001 CVPI for a friend hes about to loose 1st gear , when we went around to trans shops to see about a rebuild we got 1800-2000 dollars a few times so taking her to the shop is out of the question ,,, so my question is if we grab a trans out of a 96 with the w in the vin will it bolt in and go or is that too old of a trans ???
    "Eating Hondas and craping hyundais"
    The AODE-4r70w is one expensive bitch to rebuild..The one out of a '98+ should work ok without any issue.
    More transmission info here...
    http://www.crownvic.net/ubbthreads/u...31#Post1295031
    R.I.P Linsey Nelson
    Originally posted by MeanVic84
    Chocolate Rain. Some stay dry and others feel the pain.
      No. It's too old. While the basic tranny is the same, the wiring and solenoid block setup is a wee bit different.
      I find it a bit odd that he is about to lose 1st gear, usually, it's overdrive and drive that goes out in these cars. Methinks you need to run a proper scan of the ECM, and get some live data from the tranny to see if there is actually something broken in there. Occasionally, it's something simple, such as a MLPS, or solenoid block in the valve body that's the problem.
