ADTR.net Magnaflow cat back system
    I have a 2000 GM with single exhaust now i was thinking about getting this exhaust but it says its only for 06/07 crown vics. Should i be able to bolt this system up to my car cause it looks like just a normal single to duel pipe conversion am i right?http://www.adtr.net/shop.php?page=exhaust
    Any exhaust shop should be able to custom build the exhaust to the way you want it... muffler choice, x or h pipe, even pipe size... and you don't wanna do single to dual. You'll want true duals since there are two pipes running off the motor.
      The Panther chassis was re-designed in '03, so I'm not sure what problems that would cause with installation on a pre-'03 model.
      You should be able to get parts for dual exhaust from any parts store. You'll need to get the body mounts for the hangers from Ford or a bone-yard, but everything else is available after market.
      Ray
      Car: 2004 Mercury Marauder
      Engine/Tranny: 49k miles and bone stock....for now
        They want an ungodly amount for there exhaust systems! Over a grand for an off road H pipe???? Damn! I wonder if there a way to get anything from a mustang to work even with some slight modding?
          Anymore cutting off the cats cause more problems than the power that they gain..Unless your building a full race car there is no need to do away with the cats all together...If anything just run a set of high flow cats
          R.I.P Linsey Nelson
          Originally posted by MeanVic84
          Chocolate Rain. Some stay dry and others feel the pain.
