Street Driving with a Dominator
    I was curious what kinda streetability you could get with a dominator carb?
    With the 500+ cube big block i'm building, i'll need the big airflow. But, I hear talk of two and three circuit carbs, and it all confuses me.
    What kinda carb should I look for? Based on the heads i'll be running, and cam/compression, a 1050+ has been reccomended.
    Help!
    I've heard that the way to go is with Demon carbs...
      ITB with EFI! Fuck carbs
        Yes, YES, YES!!!
          EFI is tempting, but phayzer would make fun of me.
            http://www.hilborninjection.com/ <- get these tell him its a webber set up
              Drool!
              And my lil Capri uses a weber with the choke removed and the throttle is a bit touchy....But it is fun to drive
              I assume a race carb would be very similar.
                If you absolutely have to get a dominator, get one with a three-circuit setup. The regular two-circuit Dominator doesn't have much of an idle/cruise setting adjustability, and is more of a light-switch in power delivery.
                What is so special about the dominator, other than it's a.....dominator? Spend some time reading about them, you would be amazed with how much you can do with one. Another option would be dambest carbs (DAMBEST.COM), this guy is getting some serious power out of his equipment...if I go carbed, his stuff is what I am going to be robbing liquor stores for.
                  It'll only lead to tears
                  -Me
                  No trees were killed in the sending of this message, but a large number of electrons were terribly inconvenienced.
                    Hey, that's copyrighted.
                    But very correct, lol.
                      I dont see a little c in a circle lol
                      -Me
                        "Little C in a Circle"
                        Busted, Lady.
                          be different and run a split dominator
                            http://www.candsspecialties.com/
                            http://www.nickersonperformance.com/
                            Try these ....Nickerson is the grandfather of afterarket carb mods several of my friends run his stuff.
                              How about a Predator carb?
                              2008 Mercury Grand Marquis GS Bone Stock
                              The modern definition of "racist" is "someone who is arguing with a Liberal".--updated Peter Brimelow quote.
