View Full Version : radio wiring
arkoza63
02-26-2008, 05:56 PM
does any one have wiring diagram for the radio for a 88 cv lx
marquisman
02-26-2008, 06:00 PM
im sure someone here does, whats your project? you got a primium sound system or a regular radio? you can buy wiring kits.
arkoza63
02-27-2008, 12:22 AM
just stock. when we bought the carthe seller took out the after market head unit (just cut the wires)and just put in a ford stock unit (not wired up). i do have the plugs and a small pig tail from the head unit, but that has more wires than the harness seems too. so i'm looking for some diagrams to hunt down some missing wires i hope, or to at least match up what i got. thanks
86GmLsCoupe
02-27-2008, 01:44 AM
Here's what I could find from the12volt.com, let me know if it helps you any. Here's the link also. http://www.the12volt.com/installbay/stereodetail/819.html
1986-89 Ford Crown Victoria Stereo Wiring :
Constant - 12V+Green/Yellow
Switched - 12V+ Yellow/Black
Ground - Chassis
Illumination - Blue/Red
Dimmer - n/a
Antenna Trigger - Orange/Blue
Antenna Right - Front Front
Speakers - 5" Dash
Left Front -(+) Orange/Green
Left Front - (-) Black/White
Right Front - (+) White/Green
Right Front - (-) Black/White
Rear Speakers - 6" x 9" Rear Deck
Left Rear - (+) Pink/Green
Left Rear - (-) Pink/Blue
Right Rear - (+) Pink/Blue
Right Rear - (-) Green/Orange
Archangel
02-27-2008, 04:13 AM
And how is one to figure out which pink/blue is for the left negative and which is for the right positive rear speaker? Same with the front (door) speakers - black/white negative wires for both, how you figure which is which?
86GmLsCoupe
02-27-2008, 12:15 PM
Hermm, that I'm not entirely sure. I can take a look at my EVTM (for 86') and see if it explains it any better. I wasn't sure how helpful it'd be considering I didn't see any listings for alternate stereos, or wiring concerning the amp. Were they just all Premium Sound (digital tuner+amp w/cassette) at that point?
arkoza63
02-27-2008, 12:22 PM
trial and error? this will get me close thanks 86
arkoza63
02-27-2008, 03:59 PM
thanks for the help. the diagrams helped. the radio didn't work:ugha:, oh well we'll get a new one latter.
86GmLsCoupe
02-27-2008, 06:02 PM
No problem, lots of people hate stock radios and ditch them, plus there should be plenty in the yards. I think they are pretty damn good for a stock radio in 1980's, especially after you upgrade the dead factory speakers. Will try and get some pics of the EVTM diagram up for tonight.
gabegt90
02-27-2008, 06:23 PM
X1 Although is my original didn't sound that great I have one from a 94 mercury sable plugs right in
fordktpjoe
02-28-2008, 03:41 AM
Hmmm. different car..plugs right in..cool.
Any other models that will swap right in?
86GmLsCoupe
02-28-2008, 12:47 PM
Here's some diagrams for the Premium Sound Electronic stereo, it's digital cassette radio w/ amp (2-channel).
Zcliff89
02-28-2008, 09:48 PM
Hey i have the same problem, i put a pioneer in-didnt work- then sony gtx710 works! BUT i still have a problem, the left side speaker dont work they worked with the stock primium tape player but not with the sony now all i have is the right side and its very annoying, also i just purchased a set of infinity 4" for the dash and 6*9 in the rear. Now when i turn the volum up the speaker goes in and out as if there was too much power going to the left side and soo all my right side go in and out, j/w could you just wire from the radio plug in to the speakers cuz i think i tried and didnt work? if you guys could help its been bugging me for a year now!!!:bawling:
86GmLsCoupe
02-29-2008, 02:02 AM
I've never changed my stock radio but from what I've heard most end up running new wires to all the the speakers because the Common Ground setup (distortion at loud volume), though they do have the harnesses that should plug right it. If you just swap the stereo itself, I don't know if the trunk-mounted amp would cause any issues. Did you install the new radio with a car specific harness, and utilize original speaker wiring or splice it in? It seems like you've got something disconnected.
Archangel
03-03-2008, 02:08 AM
Interesting, so the amp really runs the dash and door speakers, whereas the rears are powered straight by the radio? Think a Premium Sound radio can run two small front speakers (4" or so) without the amp?
86GmLsCoupe
03-04-2008, 01:13 PM
I think it's certainly possible but wiring wise I'm not sure how you'd work it out because of the shared ground mess. However, I'm sure you're skill & know-how is much better than mine so you could probably work it out. Any reason you'd want to ditch the amp?
For the longest I wasn't sure if I had a 2 or 4 channel amp. I finally figured out the non-digital Premium's had the 4 (probably because they had much lower RMS output), which was probably when they amp was under the center of the dash. The more powerful digital Premium Sound stereos only needed power to the front door and dash speakers and the amp was moved to the trunk. The amp is better off in the trunk anyhow because that dash gets some serious heat and sun.
87_crown_vic
03-07-2008, 09:09 AM
i only use power harness to power the radio and rune new speaker lines to new speakers. most of these cars use a common ground speaker wiring setup.
