Tailgate weather stripping pic request
    Ok I have been fighting this since I took my wagon out of the shop from paint. I must not have put my weather stripping on right because it leaks at the top of the rear window. Now I have tried different ways and still leakage. Could someone please take a pic for me where there weather stripping meets the window.
    Thanks
    I'll take a pic for you as soon as I get the beast back from the a/c shop later today. My compressor froze up and spat metal shavings into the whole system....lovely.
      Good luck, Zach ... my tailgate hasn't sealed right since very shortly after I bought the car 11 years ago. Tried a better weatherstrip from a different car, and no improvement. I'm afraid the only thing for me to do is to piece together a brand-new weatherstrip.
        Mine leaks a bit, and everything is good.
        It might not now, since the guides were rebuilt.
          make sure the window goes all the way up. god way to check this is when the window is full up, grab ahold of it to see if you can pull it up more, if so, there are a number o things that might be wore out
            See I was wondering if my window was going all the way up. It soaks the carpet in the rear when it rains or if I wash it, really annoying to sop that up the next day.
              I'm honestly still kicking around absurd notions of ditching this 3-way tailgate altogether if I ever have far too much time and money on my hands .....
                This is how mine seals up. For most of it it pushes itself right into the fat part of the weather stripping, but on one side it's just pressed up against it. It will leak one or two drops if I hit it with one of the high-pressure guns at the car wash directly at the seam, but it doesn't leak when it rains.
                  Awesome that is what I needed! Thank you. Mine is like that except for the corners. I hope I can just make adjustments with the stripping and not have to find a new alternative.
                    No prob. IIRC, there are some tilt adjustments for the window if you pull the interior panel off of the tailgate, so that you can make the top of the window hit at the right place.
                    Your weatherstripping should be fine unless it's really fucked up. The one on mine is the original and even though it's cracked as hell, it's still holding together just fine.
                      Interesting comment .... I'll have to post pics of mine and see what you think of it. I don't know of any ways in which it could be adjusted to seal better, but I could well be wrong!
                        Those windows are a pain in the ass to make seal properly. Seems like they always hang out a little bit on the top right corner. I know I fiddled for a long time to get the thing to work on yucatec's car. I could make it seal perfectly, but then the window would bind up on the rubber. It ended up being a comprimise setting so that everything worked as expected and there was the least amount of gap possible.
