4.6 box swap...
    4.6 box swap...
    Will it work?
    as I was prepping my car to paint I found alot of frame discrepancies... and its looking like it would be easier to get a new car. The delemma: the 4.6 Engine in the Demon is basically flawless... the Tranny is roughly 5000 miles old and would make a wonderful transplant canidate.
    I have since found 2 possible options:
    1997 CV LX: blown engine and tranny... Excellent body and interior $500
    the option im leaning toward:
    1990 CVPI: no engine and tranny... sub-par body but emaculate interior $150.
    opinions?
    2000 Grand Marquis LS: Back in the Panther Life Again.
    It sounds like it would be an interesting project. If you can make it fit, go for it!
    1998 Crown Victoria P71: Former National Institiute of Health vehicle
    1974 VW Beetle
      hell... thought the 4.6 would be smaller.
        Last time I had the Mark VIII parked next to the POS while I scratched my head and held a tape measure, It looked like the heads on the 4V 4.6 were wanting to occupy the space that the UCAs were in. Your 4.6 is a 2V, right? Should be narrower. I bet it's still tight, though.
          Go for the 97, it would be a pain in the ass, not to mention, if I had my druthers Id have a 302 over 4.6 anyday.
            It's the same frame so why wouldn't it work?
              crossmember is different, not to mention, the 281 is a fat motherfucker compared to a 302. With enough money anything is doable, but itd still be a pain. Now a 302 in an aero is quite possible.
                Look up 4.6 fox swaps if it can fit in a little mustang it will fit in a Panther. Shit i was thinking about using my 99 as a parts car for a 87 two door but the 87 was way to expensive for me so I'm just going to fix my 99
                  what's wrong with the frame?
                    I'd have to do a side by side comparison, but I think my 82 is a little different than the 95s crossmember.
                      Can't be that hard, 460s can fit into these cars.
                        While I would love to see someone put a 4.6 in a box...I gotta say, you should get the '97. With that swap, you would just need to remove the '94's intake and exhaust manifolds, install the '97's, and use the sensors from the blown engine. The tranny may require a little more work, since the '97 has a 4r70w, while the '94 would have an aode, but I believe the 97's computer can control the AODE.
                        As for putting the 4.6 in a box...it should be possible. I believe the crossmember is the same, as there was a guy on CVN who dropped a 289 in his '92, using a bunch of box-body stuff (mounts, front accessories, etc). You would want to install the '94's upper control arms on the box (plus the other required components). Why? There was a guy on CVN who tried to put a box chassis under an aero, and was not able to get the 4.6 in there w/ the old-style suspension. Still, we are talking about a lot of work here, and we haven't even gotten to the part about the electronics. :drug:
                        And yes, sizewise, the 4.6 is a monster. This pic should give you a good idea of the size difference:
                        The 4.6 in the pic is a DOHC, which is slightly wider than the SOHC, and a couple inches taller. Still is a good illustration.
                        Kudos to you if you take on the project, but I'd be concerned that you would take a good car and a bad one, and make it into 2 broken cars in pieces.
                        Rob
                        1996 Police Interceptor-187K miles **Replacement DD found**
                        Engine/trans: '03 4.6, underdrives, shorties, 80mm MAF, Custom downpipes, Ported plenum, 70MM T/B, and Dyno Tune. J-modded Y2K 4r70w w/ Marauder TC.
                        Misc: ADDCO bars, Big brakes, 17" wheels, '02 steering box, and LXSport console w/ floor shift! :headbang:
                          wow... figured .4ltrs wouldnt be that big a difference.
                            Go look at a Mod motor sometime. The 32 valve Cobra motors, anyway, are actually wider than a 460. And an '03-'04 blown Cobra motor weighs a bazillion pounds .........
                              well the 91 is out... the 97 is stiill around but i think i'll stick with the demon...
