Oh well I had to do it....
    I bought a supercharger for the wagon.
    Yeah, yeah, the frame hasn't been fixed, it's got a rough Idle I need to diagnose and repair, the trans has something wrong with the governor or VB....
    But it was clean, and the buy it now was 149.99....
    Oh fuck...
      m90 or m112?
        M90. Should be good for some insane low end torque.
            oh my. I'm really curious how this works out, I'd sort of like a bit more oomph from mine and I don't feel like tearing the motor down to get it.
              It's gonna be an interesting time mounting it. it's going to be mounted in the current alternator position and be bolted to the upper intake and the TB will be on the inlet side of the blower. I want to make it look kinda factory.
              The alternator will be reloacted to the smog pump spot- and upgraded to a 3g.
                http://forums.corral.net/forums/show...ghlight=m90%2A
                Great read... Dude got 410ftlbs of torque at 2800 rpm.
                  Sweet man! Cant wait to see this.
                    Perfect for a heavy Panther. I eagerly await your results. Awesome buy! What kind of fuel management are you planning?
                      36-42lb injectors. I'm already running a TwEECer.
                        Have any plans on how your going to get it set up? There seems to be many small hard to find parts that came in the Instacharger kit.
                          Yes, I do.... Kinda posteed that already. It's gonn most likely require a custom pulley(s) to do, I need to get it to see the size and how it will be positioned. it will be quite different than the instacharger setup.
                            yeah!!!!!!!
                              Good luck It would be nice to put an M90 on Vicky But too bad the M112 would not fit that M90 Is still a helluva deal though
