Anabelle's new engine
    Block bored .030 over
    Speed Pro hyperutectic pistons
    ARP rod bolts
    ARP oil pump shaft
    Clevite bearings
    Ford Racing oil pump standard vol and pres
    HO cam advanced 4*
    Ported E7 heads
    GT40 lower intake
    Explorer upper intake
    1" spacer
    65mm throttle body
    lightning EGR spacer.
    Looking forward to seeing the progress, mang!
      mang i hope ups didnt lose that spacer
        This thread does not meet the requirements for this forum.
        Please add power adder or better heads. Thank you.
        hehe. Should be a decent reliable performer.
          Sounds like my motor pretty much, but I'm using an Explorer cam instead of the HO.
            sounds like a pretty well matched combo..hope it goes well for ya mang!
              edit: GT40 3 bar heads will be going on!!
                Update!
                ok here is the new setup:
                Original block bored .030 over
                Speed Pro Hyperutectic pistons
                ARP rod bolts
                Crank turned .010
                Clevite bearings
                GT40 heads
                HO cam 4* advanced
                1.7 roller rockers
                GT40 Lower intake
                1" intake spacer
                65mm Throttle body
                4hole 19lb injectors
                Soon: Mass Air conversion, big brakes, 3.73 trac-lock
                    Looks nasty; in a good way. Are those equal length headers? That's gotta be a lot of fun to drive now.
                      chyeah, bbk or mac equal lengths, she rides out pretty good, nice smooth power
