First off, this AOD. I'm not sure if this is the AOD being an AOD or what, but every morning when I first put it in gear, the car goes nowhere and revs up and then slams into gear. Then after a stop, I go to hit the gas and it does the same exact thing. Finally after about 5 minutes of driving it stops doing it.
To add on, while I'm cruisin and I slow down and then go to accelerate, the car goes nowhere when the pedal is pressed about halfway down. After I mash it almost to the floor though it finally downshifts. I have the TV cable adjusted to the MID setting btw.
I looked for any TSBs from Ford for these problems and I couldnt find anything.
One more thing, I put on a set of rear cargo coils about a year ago. Ever since I put them on, theres a rattle coming from the back of the car every time I hit bumps- sounds like I'm smugglin 50 pounds of nuts and bolts in my trunk. I checked to make sure I put the rubber seats back on top of the springs and they're there for both sides. Any suggestions?
Thanks.
Thanks.
