Best Wheel Cleaner?
    Best Wheel Cleaner?
    What is the best wheel cleaner i can get for coated wheels?
    I tried Simple Green full strength but it didn't do a good job.
    Is there any thing i can mix and put in a 2 gallon Sears pressure (bug) sprayer that would completely get all the brake dust and grease off?
    Thanks
    91gmblack
    I use Armor All wheel cleaner...
    Some scrubbing is required, but scrub the piss outta em, and rinse off.
    Repeat if needed...
      ya, thats what i use!
        westleys bleach white. Mind the paint though.
          I use bleach white for the white letters.
          It isnt a wheel cleaner
            it works on mine!!! maybe something else will work better though.
              I third the armoral wheel cleaner.Good stuff!
                i use castrol super clean or purple power..............u need to rinse often but it's cheap and it will do the trick.......awesome engine degreasers too!
                  Eagle One no touch wheel cleaner is good.
                  http://members.sounddomain.com/sambos86
                  My 1979 F-250 Ranger Hi Boy
                  33/12.50 BFG Mud Terrians
                  390ci with a little bigger cam
                  Holly 4 barrel with K&N
                  4 Speed with granny gear
                    Simple green makes a foaming spray just for wheels, it is different than regular simple green. It is called Proseries I think. It is THE BEST wheel cleaner I have EVAR used PERIOD. And if you have white walls or white letters forget the bleach, spray that shit on and they look new. Not much scrubbing is needed too!! Cant say enough about it. Killer degreaser also, gonna buy me a lifetime supply!Highly recomended
                      i used to use the marine stuff when it was around, it was call amazing roll off! it made my wheels the shinyest ever and brought out the white letters out nice.
                        Yep. Ealge 1. I swear by it.
                        2001 P72, 22\'s, Numerous performance and cosmetic mods
                        1994 Lincoln Continental - Signature Series
                          elbow grease usually works the best for me.
