is there a way to get the ABS codes
    its a 94 GM ls and the abs light is on. How do ya check that other than to a shop?
    not sure about the fords, but my mazda flashes and the different flashes mean different things.
      there is no flashing to it ,, its just on
        There is an ABS diagnostic connector under the hood. (Opposite side of the engine compartment from the EEC connector, at least that's where it was on my '93) You'll need a scanner than can read ABS codes.
        Ray
        Car: 2004 Mercury Marauder
        Engine/Tranny: 49k miles and bone stock....for now
          Hi Spaceblonde
          Most ABS faults are caused by bad wheel sensors an easy first check if you do not have a scanner is to test the wheel sensors with an ohms meter, a good sensor should read 800 - 1400 ohms.
          Regards
          Dereck
          President and founder of The Turbine Wheel Appreciation Society and Little Debbie Cake Connoissuer
