Street/Strip AOD from broader performance
Includes upgraded 7 clutch direct drum, wide Carbon overdrive band, large A type overdrive servo assembly, hardened inner input shaft, 4 clutch intermediate clutch, cryo treated internals, reinforced sun gear assembly and custom valve body reprogramming. Full lock up is retained with lock up style converter. Can also be used with non lockup type torque converter for greater torque capacity. Wide open throttle shift points will be set to your preference on a dynamometer. Choose from 2 different shift patterns. Stock shift pattern PRN OD/D/1, or hold manual 1st and 2nd PRN OD/2/1. Overdrive lockout position will hold 2nd gear. We also have an electric delete overdrive valve body at an extra cost available.
Price: $1600.00
Street/Strip AOD Wide Ratio
Same upgrades as above with the wide ratio gearing for increase acceleration. Valve body is also reprogrammed for wide ratio calibration.
Price: $1850.00
from pa
TRANSMISSION SUPER STREETER AOD 84/93 5.0L (PA)
Performance Automatic Super Streeter AOD Transmission for 1984-1993 5.0L Mustang.
Handles up to 450 HP & more torque than ever! Features firm, positive shift characteristics with its street/strip valve body, heavy duty bands, clutches, servo & improved lubrication circuits. Built to reduce heat & prolong transmission life while adding performance. This unit is essentially new, so there is no core charge
Gear Ratios:
-1ST 2.48
-2ND 1.48
-3RD 1.00
-OD 0.70
$1,539.64
AOD STREET SMART TRANSMISSION PACKAGE 289/302/351
Performance Automatic Street Smart AOD Transmission Package for Ford 289/302/ 351W/351C.
Handles up to 450 HP & more torque! Features firm, positive shifts with its street/strip valve body, heavy duty bands, clutches, servo & improved lubrication. No core charge & manufacturer's Forever limited warranty. Includes 12" 2200-2400 stall converter, dipstick & tube, kickdown linkage for carbs or fuel injection (great for swaps) & instructions.
$1,964.64
the pa trans are from mustang unlimited which about a 1 1/2 hour ride for me
and the first trannys are from brader performance shipping would be $140
the street smart package comes with converter,dipstick & tube, kickdown linkage while the others dont.are these transmissions any good and have you heard anything about these trannys or should i go for a tci aod trans
im looking and trying to save.my 87 cv wag is my daily driver so i cant let it sit for to long.
Price: $1600.00
Price: $1850.00
from pa
Gear Ratios:
-1ST 2.48
-2ND 1.48
-3RD 1.00
-OD 0.70
$1,539.64
$1,964.64
