got the 351 dropped in tonight, now i just need to start installing the accesories, carb headers, cut the wiper box to clear the tall valve covers, then do ignition then i can fire the motor.
Nitrous swallowing, fire breathing Windsor Now with videos
http://www.grandmarq.net/vb/showthread.php?t=5634Tags: None
ill give you a run or two off of the bottlehttp://secondhandracing.com/Home.aspx
no the fram filter is just on there to keep crap out of the engine for now. I will break the motor in on a motorcraft filter and then i have a dual remote filter set-up that will have 2 mobil 1 filters for after the engine is broken inhttp://secondhandracing.com/Home.aspx
got the Powersteering pump and alternator installed today with the belt. I got 1 bolt in the starter, Passenger side header installed.http://secondhandracing.com/Home.aspx
That's awesome... if ya need a hand gimme a call and see if I'm available. I'm always willing to get down and dirty to work on a car. Especially since your'e right down the street. 6865336\'05 Suzuki GSX-R - Daily Driver
\'87 Ford Crown Vic Country Squire - Sad to see her go
\'87 Mazda RX-7 - 302 project
Yeah.... it\'s stock. =)
got the carb bolted down and the air cleaner put on it looks like i might be able to clear the stock hood for now. the drivers side header is going to cause some trouble, i might have to cut the back tube and shorten it a little. the headers are for a mustang so the rear tube is bent to go around the steering shaft and i need it not to go around the shaft. i am going to buy an ignition next week MSD 6AL. Matt or Jason either of you want to but a Crane HI-6S it just piggybacks on the stock ignition.http://secondhandracing.com/Home.aspx
looks good!
is it soup yet?
soup?
got the throttle hooked up, the kickdown bar wont work so i will have to get a cable luckilly we have one laying around. Broke off part of the wiper housing so i was able to get my other valve cover installed.http://secondhandracing.com/Home.aspx
got some more pics today
with valve cover installed along with carb and air cleaner
side view it might not fior under the hood with the 1/2" nitrous plate luckilly i have a cowl for it.
High angle view also got the wagon front sway bar installed
just a shot under the car showing the oil pan sorry about the quality
and my shifter TCI street fighter not bad for $20
update:
got ignition installed MSD 6AL
got distributor installed
put in 6 qts. of oil and 1/2 quart of cam and lifter break in oil (it is barely touching the dipstick)
installed a motorcraft oil filter
primed the motor
eyeballed the timing to 10deg
got the drivers side header to fit but still does not clear the steering shaft
all i need now it to finish the header and supply fuel and it will fire
Looks damn good!!!
That 351 should make that car move pretty damn well. Now get that fuel runnin and fire it up!!
