Just bought a 00 merc...so i got some questions
    - How do i change the headlight bulbs?
    - If i buy the silverstar headlights, i have to buy 2 sets, correct?
    - how do i change the side marker lights?
    - where can i find accessories for this ride? they're hard to find.
    - how big of a rim size can i go with a low or medium profile without lifting it?
    2000 MGM LS
    Re: Just bought a 00 merc...so i got some questions
    Remove the flat cover that runs across the top of the radiator support. Then lift and remove the 2 black tabs that hold each headlamp in place.
    Pull the headlamp housing forward and you can now unplug the lightbulb from the wiring harness.
    The rest is self explanatory.
    You need two bulbs, one for each headlamp.
    I believe the corner lamps are held on by a nut and a screw.
    These pics should help.
    Be more specific.
    I am unsure about this one.
    The 2003 Marauder 300A F.I.T #003
    The 1998 P71 Jinbei. SOLD!
    The 2001 P71 (Flying Snow).
      As far as rim size, I wouldnt go more than 18 anyway. More than that is going to give you an extremely uncomfortable ride.
      There's tons of accessories. You really need to be more specific. Here's something to get you started though - http://www.adtr.net
      2000 Mercury Grand Marquis LS HPP.
      http://www.cardomain.com/ride/2336322
      Friends don't let friends drive donk.
