gears
    gears
    I would like to know what gears my '93 GM has. Where do I look?
    '79 Continental Town Car
    '90 Crown Victoria LTD
    '94 Crown Victoria
    You mean rear axle gears? There should be a code on the door sticker under the spot where it says "AX", and with the service manual, you can decode it. Otherwise, there should be a tag under one of the rear cover bolts that will have it. If it's a 2.73:1, it'll look like 2 73 for an open rear end, or 2L73 for a limited slip. 3.08:1 will be 3 08 or 3L08, etc.
      First place : Door sticker . Then use this http://moldyrabbit.com/liquid/data.html
      And the best place,But with your cars age....Check the differential cover. Look for a tag on the passanger side.It will be held in by a bolt.
      Now you know how to check Most 92-08 panther rear ends.
        Box axles had the same tag...
          Thanks! I'll check tomorrow.
          '94 Crown Victoria
            My bet is 3.08 or 3.27, most aeros have that ratio.
              Mine has a 3.08 with no limited slip. Yours might be the same.
              1998 Crown Victoria P71: Former National Institiute of Health vehicle
              1974 VW Beetle
                my '94 is 3.08 open rear gears
                  I checked the door sticker and then used the site...The results:
                  AXLE: Y-3:08 conventional
                  '94 Crown Victoria
                    When are we going to see some pictures of this thing!? (forgive me if they are right in front of my face)
                    1974 VW Beetle
                      My Sister is gonna up-load the pics...my digi-cam is over at her place. I'll have to remind her.
                      '94 Crown Victoria
