will a 88 mustang gt valvebody work in my 87 cv wag aod
valvebody
It should, just make sure the valve body and trans is actually the same casting. There wer some changes in 1989 and I don't know that the valve bodies will interchange directly.
It will bolt in with no problems. It really doesn't matter which valve body you use, as calibration isn't noticeably different. If I had to pick, I would instead use the valve body with less miles on it, because the AOD valve bodies do wear out.
Note, when you do this? Switch to Mercon V fluid.
Originally posted by Pirate View PostSwitch to Mercon V fluid.
Unrelated: Would there be anything to be gained by using modern synthetic fluids in an older transmission that calls for Type F?
BTW, Relik: You didn't mention what shift kit you want to use, but please don't waste your time with a B&M Shift Improver kit! I've scarcely heard them reported to do anything at all ... the one I installed myself once sure didn't do much.Last edited by 1987cp; 10-30-2008, 11:39 AM.2012 Mazda5 Touring | Finally working on the LTD again!
Originally posted by 1987cp View PostLike the stuff sold under the Mobil-1 brand?
BTW, Relik: You didn't mention what shift kit you want to use, but please don't waste your time with a B&M Shift Improver kit! I've scarcely heard them reported to do anything at all ... the one I installed myself once sure didn't do much.http://secondhandracing.com/Home.aspx
The amsoil atf is more than likely the best stuff out there, but it's also 11 bucks a quart. If money's no object, that's the stuff I'd go for. I've heard nothing but good stuff about it--even in super-finicky Honda automatics, where it seems to perform better than the Honda OEM Z1.
Bottom line: You can probably get longer drain intervals and less friction out of the spendy stuff, but I have had zero complaints with the wal-mart house brand.Originally posted by gadget73There is nothing more permanent than a temporary fix.
