PDA
View Full Version : I have decided to have Vicky's Transmission Rebuilt
86VickyLX
11-04-2008, 10:23 PM
Yep, that's right people, Vicky's transmission is basically dead. Luckily there are nearby tranny shops that have good reputations from people I know. So with this overhaul, what do you mangs recommend I have done? I was considering having the flywheel and starter replaced as preventative maintainence since sometimes the starter grinds at start up.
Lincolnmania
11-04-2008, 10:44 PM
dont do it there.......take the car to brian!
86GmLsCoupe
11-04-2008, 10:58 PM
Servo upgrade is a start, wide ratio would be nice, I went with Kevlar bands but people have their own opinions on them, and of course a Transgo shift kit.
gadget73
11-04-2008, 11:18 PM
kevlar has poor friction properties. You're better off with the 2" overdrive band.
New rear main seal is a good idea.
And yeah, I'd probably suggest Brian. I've got two of his transmissions and have no complaints. One AOD and one 4L60e (the Chevy). Whenever the trans in the Mark VII eats it, he'll get that job too.
Grand Marquis GT
11-04-2008, 11:42 PM
Brian.
Also get a supercoupe converter, works well with LOPOs too! And of course the shift kit, etc...
88grandmarq
11-06-2008, 07:49 AM
Brian.
I have yet to find a listing for a supercoupe torque converter for an AOD.
find them all day long for an AODE, but NOT the AOD.
my sources list AOD converters in 2 flavors, low stall and high stall.
low stall is for 351W trucks and police cars
high stall is basically everything else, including Mustangs, T-birds, mark 7s, crown vics etc.
Pirate
11-06-2008, 02:52 PM
I would add a B&M Holeshot non-locking 2400 RPM stall convertor (I'm burned out with the 2-3 shift lugging due to the stock locking convertors), and of course do 4R70W upgrades, such as the 4R70W planetaries, intermediate pressure plate (changes the intermediate clutch count from 3 to 4 discs, and firms up the 1-2 shift), 2" O/D band and reverse clutch drum, and the steel direct clutch shell and drum that allows 6 direct clutch discs....but skip the Kevlar. As stated previously, the basic 2" O/D band, coupled with an 'A' O/D servo ('B' would be fine, also), should be plenty strong for whatever you throw at it. Since the motor is pretty much basically stock, the flash stall speed of the B&M convertor won't be at 2400 rpm, but will help the car accelerate quicker, especially since you won't have a bog when shifting from 2nd to drive.
I would at least go with a TransGo SK shift kit, with everything set at 'Taxi/Police' along with an H.O. governor weight, or the HP kit with an H.O. governor weight.
mrltd
11-06-2008, 03:21 PM
What pirate said, except for the non-lockup converter. B&M torquemaster 2400 or 2000...
Also, if the car isn't HO powered, don't put an HO governor in it.
gadget73
11-06-2008, 08:46 PM
The 2-3 lug sucks, but I'm a fan of fuel economy, so I'll deal with it for the lower heat and lower drivetrain loss presented.
1987cp
11-06-2008, 09:43 PM
I thought you got considerably better deals on 2400-stall converters from Scott's connection on eBay?
86VickyLX
11-13-2008, 07:18 PM
I dropped Vicky off at the transmission shop on Tuesday, I picked her up to day and I must say it's very responsive and the new starter and flywheel really helped! I think the old starter was really tired and drew too much power from the system. The teeth were kind of chewed up on it, I haven't looked at the flywheel yet though. Only cost me $995 for everything, that's a reconditioned torque converter, all the internals replaced, the removal and installation of the transmission. They didn't even charge to put the new starter and flywheel in, and what's good is this shop has rebuilt some AODs in the past, one that I have driven and the car drives really nice.
