anything else i should do
    after the tranny is in, i'm doing a complete tuneup and fluid change
    plugs
    wires
    air filter
    fuel filter
    radiaotor flush
    some hoses
    change the fluid in the differential
    change the oil
    anything else i'm missing?
    Save a seal, club a liberal.
    dont forget the dist cap and rotor, check the timing, check the belts, and replace the pcv valve, screen and gromnet
    scott
      thanks Scott, i almost forgot bout the cap and rotor. i just did the pcv valve, screen and grommet last week,lol. then i seafoamed her! :snicker:
      if for some rason i have to replace the timing chain, should i just replace the waterpump as well, since iirc that has to come off to give me access to the timing chain?
        yes always replace the water pump. and use a new one (i've had bad luck with remans lately) use a double roller timing chain, when you go to put the timing cover back on, dont use the 2 small cork gaskets, they suck.........put a nice thick bead of ultra black or ultra grey there instead and install
        scott
          thanks for the info Scott! :headbang:
            dont forget to lube the ball joints, tie rod ends,etc...and most of all drive shaft u joints
              and make sure to grease the muffler bearings and fill up the blinker fluid resoivor
                where are those located? i can't find anything in my manuals.
                kidding btw :snicker: :snicker: :snicker: :snicker: :snicker: :boxing:
                  hehehe
                    O2 sensors?
                    Oxygen and Nitrous for everyone!
                    Al
