what does a code 12 mean on a 1996 MGM? Air Bag Light.
air bags
air bags
1996 Grand Marquis White, 288,600 miles as of 4-3-09
4.6L cvpi engine and pcm, Dual Exhaust, Blue Leather Interior, Keyless Entry and Remote Start, DOT Strobes, LED Front Marker Lights, Running 93 Octain Fuel.
Tags: None
ok, i replaced a blown Air Bag Module Fuse, #10 in instrument panel fuse box, now i get a code 42, any help with that is greatly appreciated. was getting a code 12 before. 1996 MGM1996 Grand Marquis White, 288,600 miles as of 4-3-09
Google tells me code 42 is:
LH Radiator Primary Crash Sensor Feed/Return Circuit Open
I'm guessing that means either the sensor connector is messed up, or the sensor itself is bad. You would need to disarm the system properly before attempting to work on it, or there is a good chance it will blow up in your face, literally.86 Lincoln Town Car (Galactica).
