POS Traction?? 2000 grand marquis
    Is there a way i can make my 2000 grand marquis into POS traction Without A new Rear End???
    yes
    just install a traction lock carrier
      Originally posted by lincolnmania View Post
      yes
      Where can i get that?? and how much?? and where do i install it at ?? and how hard is it to install it?
        You can get one from Latemodel Restoration Supply (www.50resto.com), for a little over 200, brand new. Or, you can peruse the junkyards trying to find one in a Mustang, or quite possibly another Panther. You need a 28 spline unit for an 8.8, if your car is a 2000 GM...
        It is a little bit involved to swap, and probably not something for an amateur to attempt. You have to swap out the open carrier in your third member, for the TL unit. Where are you located?
          i am in central florida
            I was going to suggest you visit Scott, but he is in Pennsylvania... little bit of a ride.
            You may be able find a local shop willing to do it for you, or you could try it yourself. Although it is possible to swap carriers and not have to 'adjust' the rear, thats not always the case. Sometimes you have to change the number and thickness of shims on either side of the carrier to bring the backlash between the ring and pinion gears to an acceptable level. In order to measure the backlash, you will need a dial indicator and a base. If you aren't doing a gear swap (now would be an ideal time), that is really the only special tool you will need. It would be a good idea to have extra shims though, and some gear marking compound to check that the gear mesh pattern is acceptable. You can find detailed articles about setting up rears all over the internet, and the 8.8 is a common rear.
              alrighty i will have to check into it thanks alot buddy
                Go to local mustang high performance shop, say you want a trac lock carrier with carbon clutches.
                  Go to local mustang high performance shop, say you want a trac lock carrier with carbon clutches installed and ask for quotes.
                    http://www.latemodelrestoration.com/...0%201&comp=LRS would this be the correct carrier for a box? It's for a 28 spline.
