PDA
View Full Version : Need someone with an '88 EVTM
86VickyLX
04-05-2009, 07:41 PM
I need a scan of the Premium sound radio pages for an '88 Grand Marquis sedan. My friend has just bought an after market radio, but I can't figure out the speakers. I have the power ground and switched power all sorted out. He doesn't want to run new speaker wires, so how can I get it to work with the original wiring and amp?
86VickyLX
04-06-2009, 10:14 AM
:bump:
87_crown_vic
04-06-2009, 10:38 AM
get your friend to spend $15-$20 on a roll of wire from walmart to run new lines for the speakers. the wire adapter/harness for after market stereos doent work with the common ground setup. i buy the harness/adapter to power the stereo and buy a roll of speaker wire and run new lines to the speakers. if your friend wants affordable speakers, might i suggest the speakers you saw in Baby during SF07. they are the Dual illumninites that can be purchased at walmart. the speakers still sound as good as the day i bought them and are impressive for the price. the lights on them dont have to be hooked up, but the speakers are about $35 a pair for the 6 1/2 and the 6x9s. i dont like hooking up the dash speakers since the dash on Panthers are fragile.
86VickyLX
04-06-2009, 10:44 AM
Looks like that's what I'll have to have him do.
gadget73
04-06-2009, 05:25 PM
There is an amp bypass kit, and a stereo install kit that allows you to just plug into the stock wiring. Go to a place that sells that stuff, and they should know what you're after. Don't cut any of the stock wires.
86VickyLX
04-06-2009, 06:03 PM
Thanks Thain, I know just the place to try! Any idea how much that stuff will cost?
zoomie
04-06-2009, 11:05 PM
i have a 87 wiht premie sound too but i used to install professionally i havnt hadf a chance to play with mine yet but i know that you can get the back ones to work on factory wiring the front ones you migt have to hardwire when i get a headsunit ill play with it and see what i can come up with just to let you know the amp does have a turn on that you might have to hook up to the blue wire on the head unit i havnt tried it yet but ill let ya know when i do. i know this system is diffrerent form my 85 so it will be fun to play with it. good luck mang
86VickyLX
04-07-2009, 10:05 AM
Amp comes on whenever the key is in accessory or run. It doesn't matter if there is a radio or not.
