1997 CVPI 4.6 Broken Crank
    My 1997 CVPI will not start and when I try to crank it the starter just spins. I think the crank is broken because the flywheel spins when the starter turns. Has anyone else had this problem?
    Thanks,
    Spencer
    1963 Oldsmobile Dynamic 88 Holiday
    1964 Chrysler Newport
    1986 Ford LTD Crown Victoria LX
    1997 Ford Crown Victoria Police Interceptor
    fuel filter
    fuel pump
    fuses and relays
    ignition coils
    spark plugs
    spark plug wires
    does the fuel pump whirr when you put the ignition to "ON" ?
    i just dealt with this today. ill try and help as much as i can, mang.
    08 Lincoln Navigator L - 233k
    03 Mercury Marauder- 63k
      do the pulleys on the front of the engine spin? if so, you don't have broken crank, some other issue, i'v also seen the flywheel bolts sheer off, had a shop replace transmission and messed up flywheel bolts and it just spun on torque convertor. look at the pulleys.
      1996 Grand Marquis White, 288,600 miles as of 4-3-09
      4.6L cvpi engine and pcm, Dual Exhaust, Blue Leather Interior, Keyless Entry and Remote Start, DOT Strobes, LED Front Marker Lights, Running 93 Octain Fuel.
        No, the pulleys do not turn, but I had somebody look while I tried to start it and the starter is turning the flywheel. Since the flywheel turns and the pulleys do not, it has to be the crank I believe. Fuel pump, etc. all come on like normal.
        Thanks for your help,
        Spencer
          Is a broken crank on a stock engine even a possibility? Barring an amazingly-unforeseen manufacturing defect, that is.
            +1
              I HIGHLY doubt the crank has snapped. Hell, you'da really known when you shut it off last.
                Hi
                More likely the torque convertor flex plate has fractured.
                Regards
                Dereck
                President and founder of The Turbine Wheel Appreciation Society and Little Debbie Cake Connoissuer
                  i'm gonna go with dereck on this one
                    I've seen it, not on a Panther, but on a dodge truck with a Cummins. If the crankshaft itself broke, you'd know it.
                    I'd also like to say, breaking the flexplate is something you are going to notice too. Did you hear or feel anything? I only ask this, because in either case, crank or flexplate, your car is gonna stop moving. So I'm wondering what were the events leading UP TO the starter just spinning the flexplate.
                      I bought it off a towing company like this lol for 400 bucks. The owners didn't pay their tow bill. So I have never heard it run. I'm swapping the motor anyway so I guess I'll tear down the old one and see what's up with it.
                        Ah okay that makes more sense then. Flexplate is the most likely thing, the material is fairly thin, so under the right circumstances like metal fatigue or extreme abuse they can break. That's what happened with that Cummins, one of the guys I worked with let his GF drive it and she must really been beating on it, because it tore the center right out of that flexplate. As for breaking a crank, there's really not much you can do to break one, unless it had defects from the beginning. Not sure if a broken or missing harmonic balancer on a 4.6 would break the crankshaft, it might. Guess you'll find out lol
                        $400 for a 97 is a hell of deal too!
                          Wow what mess mang I use to have a 97 CV LX if a torque coverter try changing the tranny fluid also sometimes that will fix the problem but if a crank then from what I hear 4.6 are not rebuildable un like the older Ford motors that are ??????
                          2000 Crown Vic LX HPP Red w/3:55 Rears
                          85 Crown Vic Stock w/HPP`s
                          07 JCL 250 A Scooter
                          79 to 91 Mercedes S Class W126 US or Euro Versions coming soon
                            Define "not rebuildable". Lots of people have rebuilt Modular engines, especially those with performance and racing goals in mind. Timing cover fitment is supposed to be a pain in the butt if head milling is required, though.
                              I'm starting to wonder if it was a good deal lol. A couple weeks after I bought that there was a '99 P71 that ran and the tranny was good and was in pretty good shape for $400 on Craigslist, the only thing wrongh with it was bad rearend.
                              Also, I do not believe the flexplate is broken because it is still in position perfectly like it's supposed to be. If it were broken, would it not be loose?
